H8 Group battery install
toejam
Looking to replace what seems to be a original battery in my 19' Limited and saw where people say it's possible if you remove a section of the tray.
Does anyone have a picture or video of what exactly needs to come out to allow the H* Group battery? I'm thinking of this battery: Robot or human?
Thanks for any advice!
If I remember right it's #5 in this diagram, and it goes where I drew the red circle. Pull that out, and the H8 fits no problem.
That is the same battery I purchased and installed today. I put my NOCO charger on it a while ago to top off the charge before connecting any of the cables. There is a small plastic wedge that pops out of the battery tray that allows for the larger battery. The guy at Walmart tried to tell me that because they don’t list that battery in their book for my truck, the warranty would be void. Ummm, 12V is 12V. What the hell? Whatever!
Bought the battery I listed at wally world and they refused to install it. I asked why and the guy said that in their "outdated" book it wouldn't work and with all the cameras watching the installers they could be sued. I asked what was the reason they couldn't install it, and he couldn't tell me, or wouldn't. What a crock of s**t.
He doesn't want to get fired. He doesn't make the rules, and it sucks, but it's understandable. I got a Duralast Platinum H8-AGM from Autozone. No troubles installing it in the parking lot.
I replaced my original battery with an identical looking one from Autozone. It's a heavy thing. I'm 76 and had to plan the heft carefully. Can't afford to drop that thang. Best to have two sets of burly hands, but I'm hardheaded. I got it done. Just a word of warning for anyone who has not lifted one of these into that tight position.
The warranty says bring it in for a replacement if there is a problem within 4 years. That’s what I plan on doing if it goes bad. Take it in for a swap. It’s easy enough to do myself.
I guess I neglected to detail that the guy there said their "Reference Book" was an old outdated one and he was only going by what it said was applicable. His reply was rude when I asked him to explain to me why they couldn't/wouldn't install it.
Even an "updated" book won't list the H8 as fitting the 1500s because they came from factory with H7, so that's what they are going to tell you they can install. It's easy to change a battery. Buy some basic hand tools and do it yourself.
And provide 12v power to the battery leads when you disconnect to avoid electrical issues. I’m experiencing multiple issues that I’m hoping will correct themselves. If not, off to the stealership for what I’m expecting to be a very expensive ECM reflash. (side steps will not stay stored, remote start will not stay running more than a few seconds, etc.)
No need to do that. It takes a few hours for some systems to come online after battery replacement.
H8 fits fine. remove the little plastic piece and bingo. Easy. Replaced the H7 in my ED with an H8 1000CCA last year. The little bugs, as everyone else mentioned will go away.
Honestly, I would disconnect the battery again for a good hour and maybe it'll fully reset everything. Mine was disconnected for hours while exhaust manifold fixed and everything came back the next day.
Had my son come over to help swap out the batteries. Connected a Noco jump pack to to the leads to keep the settings. Pulled the old battery, then the plastic block to make room for the H8. Put in the new battery, then reconnected the leads. Must have at some point accidentally lost connection because after securing the hold down clamp, and tightening the leads, I went to start the truck and had no GPS or NAV as well as the backlight color of some of the buttons were red. After running the truck for a while (a couple of road trips), and turning it on and off afterwards, everything returned to normal, and haven't seen that I've lost my settings - YAY!!
The battery was out of the truck for at least half a day before I connected the new battery.
Oh I get it, but worth a shot to try again since it's free. It's electronics and we know how sketchy Mopar are. It's free to try and only wasted 5-10 minutes at most.
Jump packs don't provide constant power.
