GM94
- Dec 19, 2025
Hey all!
I'm new here (just joined the forum, had my first and only RAM since March of last year), and have searched everywhere for a solution to this. 2019 RAM 1500 Bighorn 5.7, ~94k miles. Apologies for length of post; I don't want to leave something out that may be hiding the answer.
I used a trailer from a friend of my dad's to move between houses. I have used it before with no issue, but the wiring was admittedly pretty torched toward the 4-pin horizontal connector. First trip went great, but had a rough start before heading back for round 2. Leaving old house on second trip, and the truck wont start. Battery is drained. Pulled the manual neutral to get on a level surface and was jump-started by a buddy (ALWAYS HAVE JUMPERS ON YOU). Disconnected the trailer overnight. Went to return it the next day and, when I went to put the connector in, I noticed one of the 3 male pins was MISSING. Looked in the receptacle and there it was, lodged in. Returned the trailer without plugging it back in, and removed the broken pin. Truck operating normally. I checked with OBD2 scanner (BlueDriver), and showed code P1DF3 - ECU not initialized. THIS WAS THE ONLY CODE I HAD AT THE TIME.
The next week, we got about 3-4" of snow. Went to shift into 4WD, and it failed to do so. I noticed that I don't have a SERV4WD light on my dash off of a hard start, but I DO get one flashed when I get in after a remote start and push the button. Ran the scanner again, and had a slew of codes. My codes are in the file attached for the sake of the size of this post. I solved the initialization code by disconnecting the negative lead from the battery, and connecting it to the positive while still attached (electrician by trade, so I have also been looking at wiring as I go). Ignore the TPMS codes, I have yet to replace them. The one that really perplexed me was the C10CA - ITBM Adjustment Switch : Short to Ground code, until I realized that the 4-pin and 7-pin shared a wiring harness.
Steps I have taken:
- Replaced the battery (was 5 years old anyway)
- Located and checked fuses related to issues (ECU, TCCM, etc.)
- I will note that all fuses I pulled were NOT blown, but did show heat marks. I replaced them anyway.
- Checked battery output while running (sitting at ~15V)
I can only find posts about parts of my overall problem, and most were fixed by either flashing the ECM, finding loose or broken wires at the actuator, or replacing parts until its fixed. I also read something about plugging a trailer with a confirmed good 4-pin connector in and seeing if lights would come on. I would like to get as much input as I can before making any further moves.
Any and all help would be amazing! Thank you!
Steps I have taken:
