Snow vs. All-Terrain tires?
Bridgestone Dueler AT Ascents once again doing exactly what they should in the fresh snow today...⤵️
<pcitures removed>
Didn't slip or slide..on acceleration or braking (no ABS, no skid).
Performed flawlessly..they amaze me every time it snows..I look forward to as much snow as possible this winter..FUN!❄️
Good to know for when the H/L's need to be replaced. The H/T's have significantly less 'blocking' and siping in the tread area:
which explains why they perform so poorly in slush.
If I Were King ... I'd put region-appropriate tires on vehicles when new.
The AT Ascents are extremely confidence inspiring..I still haven't wrapped my head around how great they are!
I live in the Twin Cities but routinely drive out onto lakes to ice fish and haul my snowmobile trailer on unplowed roads up on the Iron Range. I've run Duractracs and Falcon Wildpeak A/T3W on my two 5th gen trucks. My brother-in-law manages several Discount Tire stores, so is my new tire connection. The last time that I needed tires (fall 2022) he talked me into buying Goodyear Ultraterrain AT tires. He had been running them on his trucks, so I begrudging tried (I'm not a Goodyear fan).
I've got 36k miles on these tires and can't say anything bad. They are fine in the summer and in the snow are as good as any other all-season tire that I've had on a truck. I've never run snow tires.
Dunlop Winter Maxx SJ8 - Dunlop Winter Maxx SJ8 Review - Truck Tire Reviews
Mainly because they were on sale ($127/tire) and had good reviews. I've got a set of 18" rims to mount them on and can swap them in my garage per seasonal requirements.
Have you gotten the Dunlops mounted yet? I'm about to pull the trigger on the same set, but wanted an opinion on them before I order. I am primarily concerned with handling while turning as the reviews say these are great for braking/accelerating but are prone to side slippage. I drive a lot of twisty highways in the winter.
I do have to say I'm pretty impressed with the stock Bridgestone Dueler H/L Alenza in snow (under 2"), but I'm sure a lot of that has to do with the fact that they are brand new tires with deep tread. I am guessing their capability will diminish greatly as they wear a bit.
I'm getting the Dunlops mounted tomorrow. I'll let you know.
Here in MN we don't get much snow - maybe only 50-60 inches a year - and the plows get out early so there is rarely a time we have even have an inch on the roads. The bigger issue is packed snow, ice, and those days it's too cold for salt be the effective and everything gets "greasy".
I spend 2-3 days a week on straight 2-lane highways outside town, which are usually windswept and (especially in the mornings) there are occasional icy patches.
So, where I live and how I drive, true "snow tires" with compounds that get more flexible and grippy when cold are much better than deep lug treads, or even all-season tires which have the 3-PMSF symbol.
The issue I have experienced with the Dueler H/L is when braking and turning on slippery surfaces there is much more understeer than experienced with dedicated snow tires (on admittedly lighter vehicles). I also don't (yet) have confidence that when the Duelers lose grip it'll be a gradual loss with a chance for recovery, or if it's "straight in the ditch" (or worse).
The additional benefit of dedicated snow tires is that I have them on 18" rims, and they are 'standard load' which helps to maintain some comfort when the cold brings out the frost heaves. Then in the summer, when I tow more, I'll have the benefit of replacing the 20" Dueler's with 10-ply tires for better towing (the truck isn't my summer daily driver).
And yes, I have often been that I overthink things and suffer from "analysis paralysis".
See, if I lived in those conditions, I would run studs. Keep them on a set of beater rims and swap them myself.
Except you wouldn't because they're not legal.
Well that's no fun.
We had 3" of snow last night and it was about 25° on the drive to work. Flatlanders spun out everywhere on the freeway. We don't get a lot of snow in Reno but when we do it's pandemonium.
The Ram did just fine on the OEM tires in 4X Auto.
I ended up ordering the Dunlops as well ($130/ea). They have a 2022 date code (which I am guessing is why they were so discounted - thanks simpletire.com). I am okay with the older date code as I don't do any towing or heavy hauling in the winter and will keep them stored appropriately during the off-season. I am getting them mounted today and will report back with my impressions after they've been on a while.
Same here - mine have 2023 date codes. Still, at 1/2 price from the other tire options, it's a good value.
I've been waiting for more snow before posting a review.
So far they ride just like the Dueler H/L in terms of feel, noise, bump compliance, etc despite the taller sidewalls (my Dunlops are 18" and Duelers 20").
My driveway and street is glare ice on a slight slope and they do OK getting up it, hard to tell if they're any better than the Duelers in this regard.
The Vredestein Pinza is a great all around tire. They are 3peak and Snow rated. I had them on my 15 Laramie for 2 winters in NE Illinois/SE Wisconsin. They have done well in all weather. I am planning on putting them on my 2020 Limited in the spring. I just bought it with Cooper A/T.
Nokian is what I run because we get snow, ice, and slush, which makes life interesting because it's all on the same drive.
For the "best" snow LT (Light Truck) tire, there's no single hands-down winner, but top contenders consistently praised for extreme grip include the Nokian Hakkapeliitta (especially studded) for ice/deep snow, Michelin X-Ice Snow for ice/slush/longevity, and the Bridgestone Blizzak DM-V2/LT for excellent overall snow/ice performance, while the Goodyear Wrangler Duratrac/General Grabber A/TX offer great all-terrain grip for plowing/deep snow. Your ideal choice depends on prioritizing ice grip (Nokian/Michelin/Blizzak) vs. off-road/plowing (Duratrac/Grabber) vs. longevity (Michelin X-Ice)
Thanks for this thorough review and suggestions. I'm a winter tire tire proponent and fully agree with your listing. I only ended up going with the Dunlop Winter Maxx SJ8s because they were on closeout and I got them for $130/ea. It's only been a few days since mounting them, but so far I've experienced slush, wet roads, dry roads, ice, hard packed snow, and <2" deep snow. These keep me sure-footed and are performing wonderfully. Cornering is great too; no over/under-steer whatsoever. I've only yet to tackle deep snow. Here in SE Michigan, that is a rarity, so I might not get to test out that factor.
Our part of MN (SE) got about an inch of snow last night, cold temps and slick conditions. Overall the the Dunlops did what they were supposed to do. It wasn't hard to break traction, but when they did it was progressive and they quickly recovered.
But I will say that I've had more surefooted vehicles on other snow tires. In my experience on vehicles with the same winter tires (the Blizzak DM-V2's are my favorite) having wider tires and more weight always degrades braking and turning in low traction scenarios. The 2016 WRX is still the king in this regard (low weight, rally-inspired electronics that allowed fun).
I had Blizzaks when I lived in the Upper Peninsula of Michigan. They were glorious, but their fast wear on dry roads would be an issue where I live now since much of the winter can be snow-free and even stupid warm.
  • Back
