How to confirm level when doing maintenance?
dearmosd
Cincinnati, Ohio
I have been toying with the idea of changing my trans fluid. Long story short sounds easy except how to firm level when on jacks? Is there a certain place I could place a level on, use the "off road" tools on the instrument panel?
Knowing level was important with the task for refill purposes.
When I changed my transmission fluid, i put a bubble level on the edge of the transmission housing above the oil pan. Worked out good but servicing the transmission was a pain because of the cat and exhaust beside the oil fill plug.
I just eyeballed it in my driveway. My driveway is slanted, so had to jack up the rear, which you need to do anyways to get wheels off the ground.
