Leveling Kit
G Gerard
MN
Good evening All,
I love my 22 Bighorn crew cab 4X4. The only think I want to change is that dipping front end, and also add recovery hooks. In regard to the front end, I have seen simple 2.5" strut spacer that look solid. I have also looked at more extensive leveling kits with spacers, control arms and shocks. Are there problems with using the strut spacer solution only? Thank you again.
this should be enough reason to steer you away from spacers/ pucks.
just get yourself a set of Bilstein 5100s (the most basic shocks/ coilovers you can get. anything less than that are trash) and while you're there, get yourself a set of made in US box welded UCAs from reputable brands like Carli or Thuren. Those arms and joints will outlast your truck.
alternatively, just do a full set of Ironman 4x4 Foam Cell Pro kit. those are pretty affordable too and perform much better than your regular RC and other junk.
Thank you for the excellent information.
  • DOFF
