KichoRebel
Dang it!! I was already setting all my focus on the 4" BDS with Fox 2.5 coilovers. Due to this description:going 4" does not net you more travel, unless you do custom coilovers.
BDS and other brands that make 4"+ kits all require cutting your UCA mounts to fit the diff drop bracket, and none of them advertise any scientific numbers. So the only logical conclusion is: they trade travel for ride height. Higher ride height = less travel, since your coilover is the same length, there's nothing added.
That is precisely why all those trophy trucks do not have tall ride heights.
Even if you manage to get yourself a set of shocks that accommodate for higher ride heights (4"), you'll be limited to the same droop because your CV axle is now your constrain (assuming you got the spindles and the UCA).
here's a fact: you do NOT need LT to "dance" with TRX or raptors in the suspension department. You need a set of properly tuned King or Fox and you'll be able to do it. (Powertrain is another department that's not part of this discussion)
Marketing and advertisement materials indicate 8112 ZC is on King or Fox level, but my real world experience tells me they are overly exaggerated. Carli setup is great, but it is not as great as most people would think. Carli works for 80% of the people whose talents and skillset are the limiting factor, so it feels like Carli works. But for the 20% of the people who have more talents and skills (aka, the OG guys of Dodge Truck Extreme - who ran deserts for the past 10+ years and are/ were involved in suspension development for Carli and Thuren), Thuren is the answer.
So, instead of messing with longer shocks and trying to chase 3.0 performance, pick up the phone, call Don Thuren at Thuren Fabrication and tell him you want a set of Kings with his most aggressive tuning. Then tell him you want the arms and end links and everything else. And when he asks what you want to do, tell him you want to dance with raptors and TRX in the suspension department. He'll get you straight with least amount of headache and thinking on your part.
"These kits feature proprietary FOX 2.5 coilover shocks designed for bolt-on performance, increased travel,"
So I assumed, if the drop bracket puts everything in place (geometry wise) then the coilover would need to be longer to provide the extra inches of lift.
Plus it says increased travel. I did think it was true because they are not the ones with a spacer, but instead, with a longer coilover. Although, no web page describes how much more travel you would get, which i did find it odd.
I do want both worlds if possible, I'd like to be at 4 inches but with the best offroad perf to take on whoops. Thuren hasn't pop in my search, so i will definitely check it out.
thanks
4" FOX 2.5 Coilover Lift Kit | Ram 1500 4WD (2019–2024)
Upgrade your 2019–2024 Ram 1500 4WD with BDS 4" FOX 2.5 Performance Elite coilovers for improved suspension travel, off-road performance, and on-road ride feel.
bds-suspension.com
