Broken Power Damper For 2019 Ram 1500
jclord
Hello all. I bought a used Ram from Carvana last month. While crawling underneath to see what mounting was available for running boards, I noticed a wire connector hanging loose. Appears to be the connection on the frame side broke. It's a 3-pin and I see the three prongs on the frame side.
I don't find much info searching online as far as repairing it. Hoping the connector on the frame could be replaced. Possibly I could just clean and push the pins into what's left of the broken connector and tape it up. Any suggestions?
Looks like the connector broke off the active damper sensor, it is a part of the damper and not avail. by it self as far as I can tell.
https://parts.moparonlineparts.com/oem-parts/mopar-damper-left-68356653ad
