I need some towing advice from someone that has done it.
Garvanzo
I'm planning a long family trip next summer out west. It will include a run from Florida out to the Grand Canyon, Zion, Bryce Canyon, up to Yellowstone and then to Mt Rushmore. I have a 2022 1500 with a 5.7 and 3.21 gears. I tow a 30' Jayco travel trailer that weighs around 7300#s loaded. I have a good weight distribution hitch with sway control, airbags and Cargomax springs on it already. We took this setup out to New Mexico and Texas last summer and it handled pretty good. I am a little worried that the truck isn't quite enough for the mountains and am on the fence about whether to get into a bigger truck before this trip. I know that my setup is teetering at the upper range of what my truck is rated for. Fully loaded and weight distribution hitch connected we were over payload but under axle weight rating. Without weight distibution we were over axle rating by 200lbs. I'm looking for advice from people that have towed that area with a similar setup.
Avoid Colorado and you should be fine, some of the grades they have are tough for a sedan if you have a passenger 😉. Also hoover dam should be along the way, cool to see
The only problem I see is that you will spend a lot of time in the lower gears, so the mpg is going to be terrible, but as long as you don't push it and keep the speeds down and watch the temps you should be OK as long as you don't go over the Rockies, but come up through Texas and then head north. I have pulled my RV through that country north to south and back north pulling heavy and had no problems at all, but I have the 3.92's.
You'll probably run into high oil temps ~270* in the mountains if you go through CO. I did with the 1500 and 3.92 towing my 5k trailer. Have since upgraded to HD.
The 3.21 gearing is not a liability. It will just run in one gear lower than the 3.92. The only time it makes a difference is taking off from a stop. The 3.21 will not respond in 1st like the 3.92.
Gassers run higher rpm when they work hard. That is how they are designed. Run good synthetic oil and enjoy the hemi. Take your time and watch the gauges.
Very interested in this topic, and I'm also planning to tow my RV to CO this year.
I have pulled campers for many years and agree with the statements posted. Years ago I never heard of a tow rating. People pulled there campers with cars. My dad used old Cadillac’s to tow with because the had a big engine. My uncle used station wagons.Now everyone worries about tow rating’s . Not a bad thing ,but it gets a little over board and technical at times. I have 3:92 gears in my truck. I got a truck with those gears ,because I was thinking old school of days in the past. Sure it doesn’t take much a good job,but it shifts down more than it needs to in my opinion and that bring the rpm up. To do it over again I would have 3:21 gears. That way when it shifts down the rpm would be lower and possibly use a little less gas. I no longer pull a trailer much over 6000 pounds. Current camper is around 4500 loaded. Truck gets 8 to 9 mpg at 70 mph towing. I pulled an enclosed car trailer with a car in it recently and got 7 mpg. That hurts. lol.
I live in Denver and tow a smaller trailer than you, 26' at 6200lbs loaded, with my 21' 1500 with 3:92 gears and Hemi 5.7. I agree with what the others have already said. It should be doable, even in Colorado, but won't be fun. Slow and steady.
I've found it to be a constant battle between speed and temps. My truck has the power to pull ok doing 65 - 70mph on I-70 over the mountains but oil temp gets into the 270* range and the engine is naturally screaming. I'm learning to slow down to 60 to keep the temps in check and to be safer overall.
Trips that are 2-4 hours away are easier because I can take my time but when I've got a long way to go, like 8 - 10 hours, it's hard not to push it faster when the road allows. It's not just the mountains, there are long steep grades all over the place and seems like there's always major wind.
If you're happy with your rig where you've taken it so far and this is a 1 time trip you can make due. If you're already leaning towards a bigger truck this might be a good time to make the swap. A bigger truck should eliminate the payload games we have to play and should have a bigger gas tank which is nice.
Note: gas up every chance you get and bring 5 gal of gas along in case. There can be long distances between gas stations and at 6-7mpg on my 26 gal tank I'm getting like 180 miles per tank.
I plan to get a bigger truck but also plan to get a bigger trailer at some point.
Well guys, thanks for the information but I've decided to get a bigger truck. We take a long trip every summer and plan to keep doing it for the forseeable future. You are right about the payload games and the gas tank. On the last trip we almost ran out of gas coming through Texas. To combat that, I'm getting a long bed with a big tank and I also got a 50 gallon transfer tank to put in the bed. With around 100 gallons of gas I should never have that problem again. The only decision I have to make now is to go Ram or Ford. I'm on the fence here. Pros and cons to both.
Good choice, I'm sure you'll appreciate the bigger truck.
I can't help with which truck. I'm leaning Chevy/GMC Diesel when the time comes.
Went with a 2026 Ram 3500, 6.4 Hemi with 4.10 gears, long bed and 50 gallon tank. This should do well for a while. The 100/10yr warranty makes me feel pretty good about the choice. This is a factory order, I hope it's here by June.
Congrats!
Rear air assist? (rides much better)
When you get it, make sure you push all the fuses and relays in the PDC (under hood) in tight and check fender grounds. This has been a thing with the HD's since 2019.
Also hopefully they worked out all the electrical issues since the change to Atlantis...
when I had a "19 4x4 ccsb laramie 1500 5.7 with 3.92 rear end, towed our 28' 6000# trailer out there and up to custer and to woodland park, co. from DFW. I planned my route to stay clear of high mountain passes and did fine. even coming home had very little trouble with Raton pass...long pull. just dont get in a hurry, use tow/haul. stayed under 70.
My 16' Laramie Dually Cummins 6.7 pulling a 40 ft toyhauler. This pic is at the dealer when we picked it up. Immediately installed airbags when we got back home. Also added a 40 gallon gravity fed aux tank for the long hauls, Made it almost to Texas from So. IN. with one fill up of both tanks, about 72 gallons. Truck only had 40+K on the odo when I traded it in last year!
