Help? Hey guys, I have a 2019 Ram, 1500 V8. Hemi Laramie starting issues.
Javi's Laramie
I went to start my Ram 1500. This morning with the auto start. When I came out the house i noticed, the truck did not start, so sat in the truck hit the brake and the start button. It does everything as if it's going to start but does not do anything at all. Doesn't crank over or nothing? Any ideas or experience with this type of issue
Javi
Javi
Most likely it's the battery.
No etorque? Probably a dead spot on starter if it’s not battery-related. Hit it with a hammer, or replace the starter. If it’s etorque, then it’s a 2-year wait for replacement parts. :)
What's eTorque have to do with it? It still has a normal starter like every other Ram.
No noise=no starter. Bang on it or replace it.
My 2022's starter crapped out at 36k miles. Apparently it's a thing with 2019-2022's. Hell if I know. After 6 months of f'n around with it not starting (replaced battery, cleaned body grounds), I finally changed my starter and it solved my problem.
Sounds like the starter. Mine went bad on my 2022 at 57,000 miles. I was finally able to get it started after tapping with a hammer confirming it was indeed the starter. Swapped with a brand new MOPAR and been fine since.
