Pole Barns and lifts
Gren71
Delaware
Im going to closing on my old home this week and will finally have funds available to work towards a pole barn on my new property.
At my old house I had an XL two car garage where I started out repairing old motorcycles and reselling them as a hobby before moving into jeep and eventually general vehicle work on my own stuff. Sadly I currently only have a detached single car garage so it pretty much just houses my tools and motorcycle. I know basically only what I have been able glean from google searches so im hoping to get some more insight here.
im hoping to get a 30x50x10 or 30x50x12, but cost may have me with a 30x40x10 or a 30x40x12.
im hoping maybe some of yall have similarly sized pole barns and are willing to thow some picures up to give me a sense of the scale of it.
I am also considering getting a lift. I know that I need, at minimum, 6" of concrete for a lift and probably 12-14' of height before the trusses. But i just dont know enough about lifts to know for sure if its worth it. Ive seen a couple scissor lifts that seem like they may do the trick for me, but I havent met anyone who has use one before so they make me nervous.
any and all info would be appreciate. Im probably looking at a 30-60 day lead time before I fully engage a builder and then likely 6 months before its all said and done...not including electric which I will be doing my self.
I believe the lift supports require a lot more than 6" of concrete and I'm sure you know that. Consider them a footer and go deeper. Would love to see what you end up with tho. Good luck!
Don't have a pole barn like you're looking for, but I do have a QuickJack lift system big enough for the truck. It's nice for large work/repairs/maintenance, but the jacks are so heavy they're not great for everyday stuff. You don't want to drive over them, so you have to get them out of the way when done working. Each lift is 100 pounds and over 6 feet long, so fairly tough to move around. If you're thinking of ones you can just sit on the ground, I'd definitely recommend ones you can drive over.
found this video this afternoon and it was really helpful, and made me hopeful that I wont have to get a crazy tall structure.
I'd recommend a minimum of 12' ceiling for a lift if you want to work comfortably under the vehicle. You can find all sorts of different lifts depending on what you want from them.
A 2-post lift is most popular for general automotive maintenance, because it leaves the center of vehicle accessible and allows work on wheels and suspension. You can lift a vehicle as high as your ceiling allows. There are shorter "portable" two post lifts that you can move out of the way when not in use . If you have space to store them.
4-post lifts are nice and dont usually require as much overhead clearance, for the lift itself, as most 2-post lifts, and also don't require as thick of concrete for support . Downfall to a 4-post lift is if you want to take wheels off, or do suspension work you would need to spend the extra money for the accessory jacks that slide between the two sides. And then you are still working around the tracks that your drive up on.
The low profile scissor lifts that you drive over don't lift as high, and then if doing work under the vehicle you have to deal with the lift itself. They would be good for wheel/tire, brake, and suspension work though .
I would figure out what type of lift you intend to use then build the pole barn that will work with that lift.
35 x 45 x 14 red iron steel building. Bendpak recommended a minimum 4.25” 3K psi slab for my 10K lb. 2-Post lift, but I went with 5” 4K psi slab during the build. There is no question that a lift is worth it. I use mine quite often just tinkering on my own vehicles. I cannot be crawling around on cold concrete floors anymore and the lift makes working on my vehicles enjoyable. No question that it was one of the best purchases I’ve ever made.
IMG_3010.jpegIMG_1996.jpegIMG_2119.jpegIMG_1947.jpegIMG_1946.jpegIMG_2433.jpegIMG_1943.jpegIMG_0260.jpegIMG_0019.jpeg
35 x 45 x 14 red iron steel building. Bendpak recommended a minimum 4.25” 3K psi slab for my 10K lb. 2-Post lift, but I went with 5” 4K psi slab during the build. There is no question that a lift is worth it. I use mine quite often just tinkering on my own vehicles. I cannot be crawling around on cold concrete floors anymore and the lift makes working on my vehicles enjoyable. No question that it was one of the best purchases I’ve ever View attachment 209637View attachment 209632View attachment 209631View attachment 209633View attachment 209634View attachment 209636View attachment 209635View attachment 209628View attachment 209630
Thanks! Love the steel building. Ive considered them because they dont have traditional trusses so theres a ton of ceiling height/space. Only draw back is that id end up having to frame up walls around a lot of it to be able to hang stuff and mount odds and ends. Not a huge issue, but a concern. Im still looking for a decent steel building company that services my area to at least get a quote.
Walls are definitely in my future, but it’s not going to be easy for sure. Spray foam insulation, insulated doors, jack shaft openers, and mini splits took priority. One thing I didn’t do, that I really wished I had, was seal the concrete. Not that epoxy crap, just a sealer to cut down on the dust.
