2025 Ram 1500 Limited w/factory air suspension 2/4 or 3/5 drop in process
ram h.o.
***VERY IMPORTANT*** To anyone thinking about lowering a 5th gen two things you need to be aware of for safety. There is a 1.25" long bolt sticking down about halfway on your driveshaft from a crossmember, it has nothing connected to it and with a 4" rear drop your driveshaft will be about 1/8" from touching this!!! I cut this bolt off smooth with the crossmember.
Second thing...be aware of the hard brake line that is directly above the axle track bar mount, with axle fully compressed I was only about 1/4" from smashing this line on the frame. Set your bumpstops accordingly.
***END OF SAFETY ANNOUNCEMENT***
After reading through several others posts here and on facebook I decided to see if I could lower mine by just simply making new sensor rods, this led me down the path of chopping my bumpstops, installing QA1 adjustable rear shocks and ultimately buying the IHC cut kit and timber grove 4" crm bag kit. I was very disappointed to find that the factory bags have a massive internal bumpstop in their design which only allows about 1.25" of rear drop without bottoming out on every pothole and dip in the road. This was less than the 2" I wanted to lower it for that level look. Once I started looking at a solution I realized how good these trucks look with either a 2/4 or 3/5 drop so I decided to dive in and see what I can make happen. Once I get the rear set to the ride height I want somewhere in the 3.5-5" range and riding smooth (lot of potholes where I live) then I will tackle the front.
Front issues seem to be that no one makes an upper control arm that also has the sensor rod attachment point so I believe for now I'll only be able to lower my factory bags to about 1.5" drop to keep alignment somewhat close to spec. Will update this thread as I learn more and tackle each piece.
Rear axle pulled for IHC cut kit and timber grove bags are installed.
Got everything done for now. Measurements from ground to fender are 34.5" rear and 34.75" front in aero mode (original aero measurements were 38" rear and 36" front.
Next step is figure out how to lower it another 1" all the way around if possible and still retain the front factory air bag setup.
Second pic is in OFFROAD 2 mode
Ride quality in rear is crap!!! Spent all day yesterday trying to figure out the issue. My bags are set to 6" top to bottom of bag as recommended. My shocks are QA1 adjustable and set to 18.75" ride height per QA1 website. Overall ride height of truck fender is same as rock crawlers and he has the same 4" crm kit and is happy with his so I know its possible. Finally this morning I went back through his post, read the instructions for ridetech's, maxtrac's and ihc's 4" drop kits, I then realized that the bumpstops on my 2025 are a full 2" lower overall than the pictures from rock crawlers build thread and from the pictures from each of the manufacturers instructions. See below pics...rock crawlers bumpstop is about equal with frame...mine is approx 2" lower. Both have the ring cut off and I even shaved the belltech bump stop down more trying to keep from bottoming out. Not sure if the difference is in the 2022 to 2025 year model or the fact that mine had factory air ride. Oh well... gonna go chop these off to match his and see what happens.
First two pics are rock crawlers 2022 2wd with coils from factory, last pic is mine 2025 4x4 with factory air.
Wow, that bump stop bracket is definitely longer. You have got to be bottoming out constantly. Basically riding on the frame. Strange. Looks like they need to be cut down shorter and welded back on so you have a place to mount the bump stop.
Yeah, I chopped it completely off and not bottoming out now.
But unfortunately this thing rides TERRIBLE!!! I've tried every setting on my QA1 shocks, I put the factory shocks back in, loosened all the control arms and re-torqued to make sure nothing was binding. I'm at a loss of what to try next. My Jeep rides 10x better than this thing. Feeling frustrated and my body is tired, lol. If I dial down the QA1's it rides like a 1985 cadillac with blown out shocks (very squishy and bouncy), but if I start tightening the shocks it rides like a 1985 dually unloaded...can feel every crack and orifice in the damn road (stiff as can be).
@Rock Crawler what pressure do you run in your bags at ride height?
So you have no bumpstops?
When you loosened everything and then tightened it all back down, the entire load of the vehicle was on the suspension, right?
I don’t have a pressure gauge. I just keep them adjusted at 34” ground to fender. When I add weight in the bed, I just air the bags up enough to keep the truck level.
You might contact QA1 and see if they have any advice. There should be a middle ground.
No bumpstops for now, will fab new ones once I figure out exact ride height and where I want them.
I did have all loose, tightened once on ground and jumped on it a few times to make sure. Used to that from Jeep suspension lifts.
Dang, was really hoping to match your pressure, I have tried anywhere from 33.5" to 35" ride height.
I'm gonna call QA1 and timber grove tomorrow. The shocks go from 1-18...on setting 5 they match the amount of force the stocks took to compress by hand so I used that as a base line and went in each direction a few clicks.
Been a long couple days, hopefully make some progress on it soon. My projects always seem to be way more complicated than they should be.
New day, got a good nights sleep (makes a difference when you're old, lol).
Decided to go higher on QA1 shock setting just to see what would happen. Setting 1 is softest with 18 being stiffest. Previously was going anywhere from 2-5 based on their videos and instruction manual as this is the best setting for most general use vehicles.
I turned the dial up to 8 and it seems to be noticeably better. I was having a lot of bounce before, was easy to identify at night as headlights were constantly bouncing.
Pressure on drivers side is at 48 psi with 32 gallons of fuel and me 265 lbs. Passenger side is 28 psi.
Ride height floor to fender is 34.25" and can put 4 fingers in between tire and fender. Yes, I am copying Rock Crawlers setup because he has been happy with his ride quality, it looks damn good at that height and it seemed logical to utilize measurements that are known to work well for him.
RockCrawler...do you happen to recall what setting youre ridetech shocks are set to and how many settings do they have? No big deal if not, just curious
Do your shocks have compression and rebound settings (2 knobs)? If it is only one knob, it is probably just rebound. This only adjusts the speed at which the shock expands, not compresses. You might need to go to 10-12.
The RideTech shocks have rebound settings from 1 to 24. The compression is not adjustable. I have mine set at 12 (medium) which was their recommendation for common street use. I have been happy with it so far, so I have not tried any other settings. Setting rebound too soft will cause a bouncy feel because the shock is expanding too fast as opposed to slow and smooth. You have to play with it and find what feels best. It is a lowered truck, so it won’t ride like the original Cadillac feel of the stock suspension, but I actually like a firmer, more responsive feel when it comes to suspension. Definitely firmer, but feels good to me. It’s nowhere close to the lowered trucks of the past where they beat the crap out of you.
Sorry...been fighting this thing for days. Finally made some progress yesterday.
1. My QA1's have one knob that control both compression and rebound. They also have a two knob version that will do both independently.
2. I finally figured out that my air pressure was way too high, causing my harsh ride. It finally made sense after driving through a parking lot of speed bumps and feeling the front vs back and how each reacted. I now have pressures down to 38 psi on drivers side and 24 passenger side.
3. Things got complicated with the lower pressures, the air bags were rubbing on the upper coil bucket no matter what way I shifted the mounts. I also ordered a spohn adj track bar from moe's performance in Conroe. I ended up cutting out some spacers on my cnc machine and lowered the top portion 1.25" and cut the bottom mount about 7/8" to shift the whole air bag down to make clearance in upper coil bucket. I'm really surprised yours aren't rubbing (might want to check them just to be safe).
4. Once I got the rear situated and was happy with ride quality and no rubbing I installed the front UCA's from Maxtrac. This brought my camber into spec.
5. Things got complicated in the front quickly...was trying to use the factory air ride control system...the issue is now that the truck sits lower, it will try to lower into entry/exit mode and bottoms out, then the system freaks out and goes into OFFROAD 2 mode and gets stuck there and shuts the electronics down. UGH!!! Trying to reset the system took well over an hour. I decided to ditch the effort of hooking into factory system for now.
6. Next issue was with the front struts disconnected from the factory system, if you go all the way down you can't fill them manually without jacking the vehicle up...I have not figured out exactly why yet. It has something to do with the internal design of the airbag/strut as well as a brass fitting on top of the strut that is some time of pressure loss safety valve. Will update if/when I learn how to defeat these and use manual fill without jacking up truck first. Did figure out that I can inflate with no weight on truck, then release air with weight of truck to set height. But as cold temps set in at night its too low and have to reset height.
7. At this point I don't see any value in having front air ride, the truck isn't low enough to need to lift the front to go over speed bumps so what's the point? It seems to me to a nice set of coilovers would be simpler in the front and less to worry about failure wise. I still want airbags in the rear to level out for towing of course.
I know this is a lot of info but maybe it will help someone else in the future. I thought this was gonna be a simple bolt in rear kit, hook everything into factory system and away I go. Boy was I wrong lol.
Reserved for more pics
While I was searching for help on the internet I ran across this kit for sale on facebook, it appears his have been rubbing as well.
Interesting. I wonder how rebound and compression can be adjusted using one knob?
I have a few spots where my bags rub a tiny bit. Not enough to cause any damage.
Glad to hear you are figuring some of it out. Hopefully you get it all squared away soon.
I'm not very knowledgeable on shocks, this is what QA1 website says. I'm just repeating it, lol. "Achieve the ultimate balance of ride quality and performance with simultaneous 18-way adjustment of rebound and compression valving."
Maybe the rubbing wouldn't have been an issue, but my OCD wouldn't let me run em like that.
I'm seriously considering the ridetech front setup now...these factory air struts only allow me to go down 1.5" which is unfortunately 1/2" higher than the back and looks goofy. If I go any lower they ride too soft.
Shortened my bumpstops so now I can put a new set of the belltech 1.25" bumps back in place...should be very close to your setup height now. At least I can adjust with some washers if need be. I didnt want to risk welding on the frame so I decided to bolt them in.
Just ordered the ridetech front coilovers...that hurt $$$
Will update once they arrive. I was only able to get 1.5" lowering out of the factory front air setup.
