As much as I like the MFT, it seems like it significantly limits the tonneau cover options. Has anybody found any roll-up hard covers or automatic hard covers that are compatible with Tungsten with MFT (Multifunction Tailgate)?
This one is UnderCover and has been working very well for me. Works as designed, may be folded up against the cab, but they recommend non highway when in that position. I had it professionally installed.View attachment 208033
If you're looking for a real cover, get a DiamondBack. These are for real Gs.
Heavy Duty, Hard Tonneau Covers | DiamondBack Covers
Be ready for the next adventure and protect your gear in the bed with DiamondBack. The toughest, most secure truck bed cover that’s built in the USA and comes with a lifetime warranty.diamondbackcovers.com
They're super light. Go with the ligther, ES version, and it is sorta weightless. One person install.Well first, I aint no Real G and 2nd,...... I still aint no Real G.
I've looked at those, they look heavy and I like the flush mount better
The issue is most Tungstens have Ram Box with the MFT. If that is the case most likely you wont have the silver rails necessary to install most flush mounted covers. The silver rails aren't readily available and if you do find them with shipping the cost is probably $500... I just did this dance and ended up ordering a Diamondback SE which fits a rambox MFT truck... With their military discount cost is about a push for a more secure cover
I went with the Diamondback SE. It can use either railsIf you're looking for a real cover, get a DiamondBack. These are for real Gs.
How does having a MFT affect your options on which cover to get? I don't have the MFT, so I'm just curious here...
rightonbracket.com
Rear latch is a pain to reach for vertically challenged. I’ve been using the running board to be able to reach it.Another Diamondback fan. Would like to have the rear latch open from the inside thou. View attachment 208789
Oh, so the bed is a slightly different design too...interesting.Peter at Right-On Brackets has developed these and they are now available for order. One member here has said they work, I have order a pair and will confirm.
5th Gen RAM Truck Bed Replacement Brackets - Install A Tonneau Cover
Replace Stock Truck Bed Brackets To Allow A Tonneau Cover To Be Installed - USA Made Steel Right Angle Bracket - 5th Gen RAM Truck Bed Replacement Brackets.rightonbracket.com
