Mr. Sunshine
- Dec 22, 2024
Where did you get them installed? I live just north of Detroit up 75 about 45 min/ Also what setting did you put the front at? I know they can go up to 3.0-3.2"
3" is the max. going up more than 3" you'll risk overextending your CV when the suspension droops.Where did you get them installed? I live just north of Detroit up 75 about 45 min/ Also what setting did you put the front at? I know they can go up to 3.0-3.2"
Howdy, I got the Eibach set from a retailer online for a really good discount. Most dealers charge $175/hr + but my preferred dealer installs for around $100/hr. So I go there pretty much all the time. They know their stuff and they protect for warranty/lease return when I want to take parts off.Where did you get them installed? I live just north of Detroit up 75 about 45 min/ Also what setting did you put the front at? I know they can go up to 3.0-3.2"
This is my hesitation on the Eibach or any rear coil lift for me. I am coming from a 2500 but I had no idea how much the factory 1500 rear coils would squat. I do not have the ORG on my Night edition Bighorn and when I haul my SXS or boat it squats pretty bad. I was looking at the Eibach 2/1” to give me the level and an extra inch in the rear but didn’t know how soft the coils would be compared to stock. I love the ride of the stock springs ( better than the 2500 ride) but not sure Ill gain much with the inch lift if they are softer than factory. I wonder if It would be better for me to look for factory ORG coils if they give an extra inch over non ORG coils.A little more experience and having moved some heavier stuff in the bed: the rear springs seem to compress more than OE ORG springs. Not a surprise based on reviews, but real world experience. I had the bed loaded pretty full over the weekend and the nose went up. I'll have to keep an eye on the settings in the front and decide if a little less lift if I keep hauling more.
Bag it. $130 on Amazon. Fix you right up for hauling and towing. Air down and get all the benefits of the offroad coils.This is my hesitation on the Eibach or any rear coil lift for me. I am coming from a 2500 but I had no idea how much the factory 1500 rear coils would squat. I do not have the ORG on my Night edition Bighorn and when I haul my SXS or boat it squats pretty bad. I was looking at the Eibach 2/1” to give me the level and an extra inch in the rear but didn’t know how soft the coils would be compared to stock. I love the ride of the stock springs ( better than the 2500 ride) but not sure Ill gain much with the inch lift if they are softer than factory. I wonder if It would be better for me to look for factory ORG coils if they give an extra inch over non ORG coils.
They're progressive. The deeper in the stroke you go the stiffer they get. But they're for off roading not towing or hauling. Sorry. Just so you know, when I air the bags down They are not stiff.It’s an option but I have had airbags on three other trucks. I don’t tow all the time and even though minimum air pressure is low I still feel like it stiffens the rear up too much. I have looked into SUMO and Timbrens as well. I was just hoping the Eibach was at least the same stiffness as factory springs but gave the extra 1 inch height.
What setting did you put clip on and did you replace your upper control armsView attachment 201840
This was my last one. Trying to do better this time. I added ORG rear springs, Bilstein 5100 front leveling and Wildpeak 295/70/18 on TRX wheels. I liked it but it never really felt just right. Maybe it needed an another inch lift or something. Or the tires were just a little heavy, not sure. Either way, I guess we learn from practice.....
Just picked up the Eibach 2Rs. Had local shop install along with set of KSP UCAs and Timbrens. Left it at 2" setting for now until I grab wheels and tires. I'll also swap out front and rear links and rear sway bar down the road soon. So far I love the ride but havent had much time to run it around.Ok, so I've had a couple weeks on local roads, loaded and unloaded bed, and now drove across MI lightly loaded about 250 miles each way. It's really about getting accustomed to the change. The Eibach system at first seemed high in front, but it's the typical illusion. The bed cover and rails tell the story: there is still a little rake. The front came up and going from ORG rear to the Eibach rear 2R setup it actually went up a little also.
The biggest difference is the progressive spring in rear that makes it different and compress more, and just ordered a Hellwig sway bar to see how that feels different. Had that on the last one so will stay tuned. But, the bigger tires don't seem to have much impact as I didn't have 3.92 on last truck. Maybe the Hurricane is that much better (sorry Hemi fans) but the launch and stop seems better.
Basically, just like advertised, the around town ride is more compliant than stiff. The highway ride is better or as good (tire change at same time maybe not best call for comparison) but overall happy. Don't look for a 3-4" lift for sure. This is more a level/lift from the ORG for sure. I still get a little rub in reverse lock, could be Mopar mudflats? Not 100% sure on that. The tires still seem pretty close on the front panels, but 295/70/18....
Overall, happy with solution. I'll be heading up north over Thanksgiving and hitting hunting roads and some other hills/Northern MI "mountains" so will capture some details. I think think the ride quality is better / softer than Bilstein I had on last 5th Gen truck. I haven't ridden in Fox setup yet but may have access next month.
To those waiting. on me to ship some free parts? Sorry I'll catch up ASAP.
