Need to replace lower ball joints. Would you replace the ball joint or lower control arm?
Cajuntec
Looking at Rock Auto - LBJ's are available by themselves (Suspensia or Delphi), but would require me to press them out. I don't have the tools necessary to do so, but I think if I looked at Autozone, they probably have something I could rent (maybe).
I'm also seeing lots of complete Lower Control Arms, with LBJ's already installed, for about $160 each (same brand - Suspensia).
Is it worth the couple hundred dollar savings to just get the LBJ and press them out myself, or go with the complete assembly?
Also considering some aftermarket on Amazon, factory from Ram (super expensive), and might also do the UBJ's / Whole UCA at the same time.
By the way - related to this - Anyone know what the little connector on the upper control arm is used for? My truck, two neighbors trucks, and just about every one I've seen in the parking lot at work have it, but nobody knows what it's for. It's the little nub that looks like a lift assist arm would attach to (like what holds up a hood, trunk, boat storage locker, etc...). No idea why it's there or what it's for.
All the best,
Glenn
I'll cheap out on some things but suspension is not one of them. I usually go with Mopar or Moog for parts that keep me alive. I haven't looked at these components for my 19 yet but Moogs for the older models were typically fitted with replaceable ball joints. So you swap out the entire control arm this time but you can replace just the ball joint in the future.
The little connector is where the ride height sensor attaches for trucks equipped with the air suspension.
change the whole unit. Pressing things out are just pain in the butt.
Also if you wanna buy auto parts from Scamazon, be sure to Google the brands. Too many "brands" on Amazon do not exist - no result returned on Google, no storefront, no location, no website. Even if the item is listed as "Made in USA" do the search because I can just photoshop "Made in USA" on my iPhone but in reality it is not.
the units he is referring to are from ROCKAUTO not the jungle store, so probably okay.
All the best,
Glenn
have a picture of what you are referring to above?
i know. just offering additional information since he did say he is also considering amazon stuff.
100% be VERY careful with amazon or feebay for that matter
they don't list any for 2wd but they actually but are the same part number on mopars website just throwing that out there for any 2wd guys and i bet the limited control arms are the same
yeap i always do Google search on Scamazon stuff and avoid feebay like a plague lol
or the easiest way is to... buy from manufacturer or authorized dealers directly.
What is making you want to swap your LCAs? I’m assuming ball joint or bushing wear but like what symptoms are you having?
LBJ needs to be replaced. Knuckle will just flop to the side with no tension at all if the UBJ and tie rod are disconnected (noticed during CV shaft replacement). Truck also makes a clunking noise from the passenger side. Not sure if it’s the LBJ, bushing wear, sway bar link, or something else, so I’m just replacing it all since I’m tired of playing “find the noise”. Probably will do the shocks as well at the same time.
All the best,
Glenn
All the best,
Glenn
That clunk is probably your intermediate shaft. Goodluck.
If you need a low mileage 3.21 diff with new shafts lmk. Lol
It’s not. I replaced that this year when I did the CV shafts. And I rebuilt the one that came off so I have a spare if I ever need it.
All the best,
Glenn
I have a 2019 ram 1500 with the air ride, suspension, newer body style the shop I took it to says the lower ball joints on both sides need to be replaced. I have 81k on the truck. Can I just buy the ball joint and have them pressed out or do I need to buy the whole control arms? I’ve looked on the Internet. I’ve asked different companies, different parts store companies and I get different answers so I’m asking the ram family lol thanks in advance!
They are not serviceable per say, but I seen a guy that did some grinding and what not. Just buy the Mevotech or Moog UCA and call it a day. Then you'll get new bushings as well.
Technically no. And the mopar parts are ridiculously expensive. I have mevotech ttx for both uppers and lowers and theyve been great… greasable but apparently not servicable either. Fairly cheap though so whatever
