2019 Ram Rebel Air Ride Issues
Bwalt15
I have had intermittent problem with my rear driver side dropping when parked. It doesn't always do it but it seems to happen more often when it rains or cold. I pulled the fuse for the compressor and it didn't drop overnight so I don't believe I have a leaky bag.
Any help would be appreciated. The dealership just said probably a small leak but they couldn't find it.
Thanks
Thanks
Sounds like something is commanding the compressor to pump down that corner,
basing on the fact that it is not dropping when the fuse is pulled.
Battery failing due to old age and causing computer glitches, poor ground causing glitches, failing suspension control module?
If going the DIY way. ALFA obd, OBD link MX+ and ALLDataDIY. for starters.
