anyone got an idiot's guide to suspension? 2020 Rebel (not air suspension)
kc9umr
97k miles... probably time to do a few maintenance items... suspension time. tires... I'll wall on my sword here and admit my ignorance. time to learn something.
I'm seeing a lot of people going to the 5100s - I'm an electrical guy, so learning here. been a long time since I did the coiler replacement on my 2002 explorer.
My goal is to replace my tires with the same ones that came on the truck. had good luck with them. why mess with what worked?
1) the rebel is ~1" higher than a normal Ram, right?
2) is the most cost effective thing to just replace the struts with the 5100s?
3) will I need to replace anything else? (I'm thinking ball joints, most likely)
Yes, I'm aware that we need to see what's worn before we can make a 100% statement. Just looking to start figuring out what things I need to acquire. I was half wondering if there's a decent enough 2" lift (rebel +1") kit to just replace all the parts. Probably best to just go back stock, though.
Your budget is going to matter and honestly if you're staying stock size tires. I personally wouldn't lift more. I just did a BDS 3" lift and replacing all of my suspension with new. I had 90K+ and wasn't planning on doing again. It can be a rabbit hole, depending how far you want to go and spend.
I'm not sure with the Rebel, what the lengths are, but according to Bilstein 4600's and 5100's have the same measurements. So the only difference is the height adjustability. They both have the same valving. I'm guessing the Rebel just uses the coils for the extra 1".
How much do you want to spend?
How far into replacing for new parts do you want to go? UCA, LCA, Tie Rods, Sway bar bushings, Rear control arms, panhard bar ..... It's going to also depend how long you plan to keep the truck. That saying, buy once, cry once....
I can keep going..
5100's, sway bar end links and bushings, tie rod ends, it's easier to get new UCA's than replace the ball joints honestly. The Rebel gets the 1" lift from the springs, so you can set the 5100's to 1" before installing and have 2 front/1 rear. That'll keep a small bit of rake as I have 3 front/2 rear and it's just enough to not make the truck look nose high.
I can keep going..
View attachment 207478 View attachment 207479
Well, at the moment I'm looking at "what do I need to do to be stock" - sounds like the next response has most of it. UCAs, tie rod ends, sway bar end links, and shocks. I see "position: Front" - again... idiots guide - are they the same on all four corners?
Got enough life stuff looming right now that "let's make it drivable and not destroy tires early" is the goal. Was even thinking about checking with the youth at church who are headed to be mechanics to see if they'd be interested in helping with the install. a lot of this stuff isn't super hard, but my driveway isn't suited for it. Like I said, replaced the coilers once upon a time on another truck. but I know my limitations!
next dumb question.
Again, I know my limitations. And I appreciate the input from those wiser than me on this topic. I'm comfortable with electrical, comms, electronics... but this is a little out of my wheelhouse at the moment.
pre-assembled coilovers are nice because they remove the need to deal with the issues of compressing, and bad things happening. Again, I have the rebel - does that change what I should be shopping for, or is the lift achieved with the strut settings?
I've found rear control arm sets with bushings.... front suspension kits with all the tie rods ends, UCAs, sway bar links and ball joints... that's only $3-400 worth of parts.
Aftermarket lifts will be the same among our trucks, you'll just get 1" less overall lift. So if it's a 3" kit for a non-Rebel then it's a 2" lift for us. Compressing coils isn't as scary as it's made out to be as long as you're careful. I've done it multiple times with rented spring compressors.
just copy my old homework and you're done
if you're always heavy like I am, then:
one easy rule of thumb is take whatever that is on the market, (ie, the Fox 2.5) and minus 1" and that will be your new height. For example, Fox 2.5 come at 2" lift, that is for non Offroad Group/ non Rebels, so they gain 2" lift. On Rebels, because you have 1" from factory, you will only gain 1" with the stock Fox 2.5.
Another method of thinking is, disregard what Rebel's 1" come with and start from regular truck's 0" lift. The logic is, most of the legit kits use stock 0" lift as reference, and once you remove the stock suspension from your rebel you start from 0".
But whatever you choose, do not go over 3" because that CAN mess with your CV.
Also do NOT do pucks/ spacer lift. (here: Technical Tuesday: Suspension Lift vs Pucks - Why Pucks/ Spacers are Never Good Ideas)
Also, as someone who's done plenty of lift kits for customers, these are the brands you should consider based on your budgets:
  • Lower cost
    • Bilstein 5100 or Ironman 4x4 FCP plus whatever else is needed (more on that)
      • *note: ironman 4x4 FCP is not that wellknown in the Ram world but they are great actually - tried it on a customer's truck in the desert and it actually performed better than 5100 due to the oil volume and piston design.
  • Medium cost
  • Carli 2.0 Commuter Pack
    • comes with everything you'll need, but downside is they are based on Icon 2.0 shocks... and Icon tend to prematurely leak a lot. I'd like to think Carli does their own QC but we shall see about that)
  • High cost
    • Stock Kings or Fox 2.5 DSC, plus whatever else is needed
  • Ultimate
    • Carli 2.5 Performance Pack (comes with everything you'll need, takes out the guesswork completely) or
    • Thuren Kings (tuned specifically for YOU - how YOU drive, the type of terrain YOU drive on, how YOU want the ride to be, your constant load, etc. But will need to buy some other things separately. This is the Ultimate function over budget option before going full custom)
  • Full custom
    • Long travel kits with fully custom welded parts that require cutting your front shock buckets and lower arm mounts for longer lower arms and bypasses. This is the ultimate option that allows you to run 200+miles a day in the desert but on-road performance can be seriously impacted)
All others are brands that I'd stay away from due to bad experiences (rides, quality, etc)
Things that you will need:
  • UCA:
    • use Carli or Thuren.
      • Avoid Amazon brands despite the price tag. Icon is popular, their tubular ones are fine but a royal pain in the rear to put together. Their billet ones sheared on my customer's rig less than 6 months after install and that's not the only story i've heard.
  • Rear springs:
    • choose whatever that can get you to the height you want.
      • You can use spacers here, since it's solid axle and not coilover but I honestly don't recommend.
      • Personally I ran Carli Rebel HD before and now I'm on Clayton 2.5" Triple Rate HD due to weight.
  • Rear arms:
    • entirely optional.
    • If your bushings are shot or on the way out, then change them out.
    • If you party a lot on dirt, change them out.
    • I didn't change mine because... I'm so heavy on the rear axle that the weight actually helps with keeping the arms in check when I party on dirt. Some people swear by Core4x4, but if I was to change mine I'm going Thuren because Thuren actually test them in the desert before releasing them.
  • Rear sway bar end links:
    • change them out because you're lifting the rear.
    • I use Carli ones and they are fine.
  • Rear sway bar:
    • Entirely optional.
    • People say they make a difference but again, I'm so heavy in the back it doesn't really matter. Also I set my rear Fox 2.5 to full stiff (high and low speed - because i'm too lazy to change the settings every time I hit dirt) so that helps with mitigating body roll in the back.
  • Front sway bar:
    • optional.
    • some say they make a difference but with the current heavier rated springs in the front i have very low body roll. Even with the stock Fox 2.5 with low speed at full firm I have very low body roll as well.
  • Front sway bar end links:
    • optional, imo.
    • If your ball joints on the end links are shot then change them.
    • SuspensionMaxx make good ones.
  • Front lower arms:
    • if your lower arm bushings are shot or the ball joint is shot, change them. If not, leave them be. Not difficult part to replace.
  • Front brake lines:
    • you shouldn't need to change them unless you're doing Carli 2.5 Performance.
    • Check with Thuren if you will need them if you go Thuren.
    • All others, you will NOT droop your front enough to require them
Things that you may or may not need:
  • Tie rods:
    • check for damages or wear
  • CV axles:
    • check for damages or wear or noise.
    • If you are replacing them, go with extended travel ones.
    • I have the stock ones now for 40k miles and at least 10k is on high speed dirt - i run my truck hard on dirt. just waiting for them to go and i'll get the extend travel ones, or if i move on to a power wagon then that' will be the next guy's problem)
  • Sway bar bushings:
    • If they are making noise, change them.
    • If they are shot, change them.
    • The poly ones are better
  • Lower ball joints:
    • Change them along with the arms
  • Lower arm bushings:
    • Change them along with the arms, make life a lot easier than to press them out
      • unless you have the person working on your truck then, by all means change the bushing only.
Yes it is a long list and yes, it gets expensive. If anything, going back to stock is probably the lowest cost way to do things correctly lol
THANK you!! lots to read when I get done with this week's homework!!
no worries.
just copy what i got and skip that part of the headache, go straight to check for any wears and tears hahahaa
No, the front are struts and rears shocks.
The front and rear lift is achieved with higher coils. That's why when you look at the Bilstein settings, they have 2 different, depending what OEM suspension you have.
If you go pre-assembled struts, you will only get what they are setup for. So if it says 2.5, then it would only be 1.5" from where your Rebel sits stock. I hope that makes sense.
The above post is probably outside the budget you want to spend, just a heads up. Again budget is goin to control what setup you go with.
Mevotech sells HD TTX version UCA and LCA with all new bushings/ balljoints. I'm running the LCA since I have the BDS 3" kit that comes with UCA.
I'm also running the TTX tie rods as well. SuspesionMaxx Front sway bar links. Again Budget will determine.
Rear I have CORE4X4 sway bar links, Hellwig sway bar and CORE4X4 control arms.
Again... I'm learning.
At this point, I'm going for "replace what was there". the lift just ain't happenin'. Got hit with some other stuff recently. fun times.
