troutcommando
I purchased a new 2020 1500 BigHorn and within a month a mechanic (nephew) installed rear airbags and a 2" leveling lit to run slightly larger 32-33 inch tires than the factory 31s.  A few weeks ago I had it the shop for a yearly inspection along with servicing the the engine oil change, diffs, transfercase, and transmission fluid change spark plug change. I also asked him to find the "clunking" sound heard when driving on gravel and dirt forest roads. My mechanic (who I have used and fully trust) for over 20 years called and said the front CV shafts and diff hubs where totally shot and it was due to my running the factory non-extended CV axles after lifting the truck. He also suspected internal diff damage or excessive wear on the shaft that drives the pasesnger side axle disconnect/outer stub assemble. After pulling the diff he called and asked me to come and look at the excessively worn internal shaft that will also need to be replaced. So at this point, both outer diff stubs, an internal diff shaft (passenger side), and new extended CV joints will need to be replaced. This will not be an inexpensive repair...probably $3K-$3.5 when done. To compound the issue are part shortages for RAM front diff internal parts from Stelantis, specifically the needed shaft part for my diff.  Our local RAM dealer says the factory 125K warranty will not cover this repair as I had the truck lifted/modified and did not install the extended CV shafts...my bad for not investigating the 2" lift a bit more before installing back in early 2020. I don't drive my truck hard and typically baby it when in 4 wheel drive...it has everything to do with the  changed geometry of adding the 2"  leveling lift.
Bottom line: Leave your truck suspension stock. If adding a 2" or higher lift, make sure you investigate the details with a knowlegable mechanic. Buy a new truck with a factory lift that comes with the factory extended CV shafts that will be covered under the factory extended warranty. My truck may look more rugged with the leveling lift kit, 32-33" tires, but in reality' it has cost me more money when buying tires, additional lost fuel economy, and now expensive reapirs to the front diff and replacement CV drive shafts. My truck before this was a 2005 Chevy Silverado 4x4 purchased used with 77K miles that I sold after 300K miles after buying the new 2020 RAM. I really enjoy driving the RAM (more power, great 8sp tranny, excellent towing capability) however the maintenance and repair cost for the RAM is now 4X at 117K miles than the stock Chevy Silverado driven to 300K miles.
