Failed water pump 63k miles
Pribilof
What a joke. Only 63k miles on this 2019. Water pump is leaking from the shaft seal. Truck gets to 224 degrees idling in 70 degrees weather - immediately drops to 204 degrees as soon as you start moving.
Has anybody replaced their water pump? Looks pretty straightforward on the 5.7. what's the recommended replacement pump? OEM going to fail again? Gates, etc? Just a crappy design? Never had a water pump fail in my life, including vehicles I took to well over 200k miles.
63k miles and your complaining about a very common maintenance repair part failing guess everything is suppose to last forever.
Save the my last xxxxx went this many miles and never had a waterpump fail.. true is its a hit or miss hell some water pumps fail right of the box. Replace it and move on.
Maybe "very common" on FCA vehicles but I've never replaced on any other vehicle in my driving career of over 1.2 million miles. Thanks for the otherwise useless response.
Sucks it happened, definitely early, but there was something about 2019-2020 water pumps going bad early. I wouldn't hesitate to buy the current factory unit, which has been upgraded, but would have a good independent shop do the install instead of the dealer to save money, this is assuming you are no longer under any warranty?
I replaced it last night. Took about 4 hours total.
OAT coolant.
I used a Gates water pump (P/N 43579), put on a new Gates belt (P/N K060730) and a new Motorad 203 degree T-stat (P/N 5416203) while I was there.
Pretty straight forward R&R job? Any special tools needed? It appears I have a leak from my water pump (2019 Ram 1500 5.7 Hemi, 121XXX mi), and I’m looking into replacing it. I suspect the old/bad/stuck open thermostat I just replaced caused the water pump to work overtime, leading to the leak. But, it appears the leak is from the water pump, and this is known issue with this model year, so I’m not too concerned.
I HAVE 2019 BOUGHT IT USED AND OWNED IT FOR 3 YEARS SO FAR HAD 3 WATER PUMPS REPLACED THROUGH EXTENDED WARRANTY ALREADY. GRANTED THE 1ST ONE FAILED AROUND 90K MILES AND THE OE PUMP. THE 2ND PUMP FAILED DUE TO 1 DEALERSHIP CRUSHING THE GASKET AND OTHER PUMP HAS LASTED 20K OR SO NOW
GOOD LUCK
I wanted to add my experiences. Not with my current RAM but my last 5.7 I had to replace the water pump twice in 200k miles. It hasn't been a constant issue in my experience but is definitely a regular maintenance item.
I understand some cars have no water pump issues and run indefinitely, meanwhile growing up I felt like I changed a water pump on dang near every Ford vehicle anyone around me owned.
Hose clamp pliers and a socket set. Pretty easy.
I'm not sure if it's like this on the current engines but on the 2006-2008 engines if you had air in the coolant system there was a potential of overheating and dropping valves.
I would take extra care to burp the system and get as much air out as possible if you do this at home. Not worth the risk of losing your motor.
Water pumps do seem to last longer nowadays. When I was young, 25k was considered pretty good out of a water pump. I've changed at least a half dozen on various cars and trucks I've owned. But not in a long time. Cars in general are just a lot better now.
I also remember, when I was a kid (in the 60's), when someone's car in the neighborhood turned over 100,000 miles we all went to look at the odometer.
