HOW TO: Adding FRONT and REAR Parking Sensors
The Bezels are for the front lower grill and two outer fog light surrounds. Each piece has 2 sensors for a total of 6. Fitment is keyed on each to allow for the correct orientation of each sensor plug. I bought all OEM parts online from McKinney CJDR in Texas. Their online site had detailed diagrams and list/show specifically where each part is to go. I wrote the locations down if you need them for each oem bezel listed by @FM45
You are missing #23 and 24 or
HU-CRR012-BZ and HU-CRR013-BZ from your site
Great, thanks. Yes, I'd like to see your list. From the HUSHAN site, I think I received two flavors of the same two bezels?
HU-CRR017-BZ
Ram
Ram 2019-2023
Parking Sensor Bezel
Front Center RH
68335621AC
HU-CRR018-BZ
Ram
Ram 2019-2023
Front Center LH
68335620AC
HU-CRR019-BZ
Ram
Ram 2019-2023
Front Center RH
68335632AA
HU-CRR020-BZ
Ram
Ram 2019-2023
Front Center LH
68335631AA
Five years ago, I started this thread with the hope of adding parking sensors to my 2020 Laramie. This past weekend, I successfully installed the front and rear sensors following the detailed instructions from @FM45. They are spot on and include everything you need for an easy install. I would add and/or change a few things to make things easier:
First off, buy a 1oz tube of Dielectric grease. Grease all connections that are NOT video connections.
1.) I used a different front harness because I have LED fogs.
2.) Remove the rear tailgate to access the middle harness connector sandwiched between plastic.
3.) Order extra pieces from Mouser and buy a micro pin crimper.
4.) Make the 36" harness 48" - the extra length was perfect, make the other two harnesses 18-24". I made mine 24", you can always shorten them.
5.) When installing the C2 pins into the connector under the driver's seat, pins 45, 46 get inserted 180 degrees different than pins 10-13. Also, after you remove the silicone plugs for these pins, cut off the smooth end, then drill a 1/16 hole through the middle to slide it onto your wire to seal the connection after insertion.
6.) Plug A is difficult to remove - slide a 1/4"x1/16" thick piece of metal with a 30 degree bend at one end, up into the back of the connector from the bottom and try to push the tab toward the engine. Then slide the connector DOWN.
7.) Pick any spot on the Can block behind the headlight switch.
8.) Instead of pinning C1 ground to plug B pin 10, crimp a 1/4" round terminal to the end and connect to the vehicle ground post under the park module in the left kick panel. Either method works fine though.
9.) You can pin C1 fused ignition power supply to plug B pin 3 if the female side has a pink wire with green stripe. (Mine did and it was the fused ignition)
10.) You do not need to remove the driver's seat.
11.) Buy a park module with the 3 connectors and wires attached with at least 2" of wire. I crimped my wires to them and put shrink tube over the connection. I also lucked out and found the correct module with connectors when I bought it.
When you are finished, this mod will look like it was factory installed.
Compared to kits being sold by infotainment, THIS is the way to go and is comparable in price, plus it looks and feels factory instead of running wires through firewalls or tapping into the accessory outlet.
Five years in the making, and thanks to the work by @FM45, I now have factory front and rear parking sensors.
Using your write-up to get my parts list for this mod on my 2021 1500 Big Horn Ecodiesel. Does anyone know how to narrow down the correct module and front and rear wiring harness? Looking on BAM I am finding multiple parts with varying prices but don't know the difference for each or which is correct one to order. Below is the list for the 2021 1500 Ram under the Park Assist section on BAM. Any help would be greatly appreciated.
Parking Assist Module: $63.00 - 69.22
Has anybody done this yet on a 21 and newer truck? I found there is a different Park Assist Module for 21-24 Rams than the one that was used on a 2019 ram in the write-up. Physically they look the same. Just hope the pin locations are the same.
For reference the part # for 21 and up Park Assist Module is 68464879AG
I bough a used 68271822AI per FM45's writeup. I have completed install of the rear only on my 22. I flashed all the settings per FM45; except I choose Rear for
I bought a used 68271822AI module; per FM45's writeup (didn't realize until now it is specific to 2019). I have completed installation of only the rear so far. I chose Rear for VehConfig1-PTS Config: I now get the icon in my cluster but it says SERVICE under the icon. Wondering if it's the wrong module, or a bad sensor. I bought the cheap Amazon sensors. No error messages when I scan. How do you check the sensors--just trial and error? I'd like to verify the sensors before I buy another module. I see you say 68464879AG; but per the catalog 80 also fits MY22. Do you know the difference?
Thanks,
Brent
Front Wiring Harness: $33.10 - $66.42
68475598AA
68475599AA
68489200AA
68489201AA
68489202AA
68489203AA
68489204AA
68489205AA
68489206AA
68489207AA
68489208AA
68489209AA
68489210AA
68489211AA
68489212AA
68489213AA
68489214AA
Rear Fascia Wiring: $58.63 - $103.73
68475602AA
68475603AB
68475605AB
68475607AB
68475608AA
68488370AB
68488371AA
68488372AB
68488374AB
68488375AA
68488381AB
Did you get an answer on the module PN?
I bought a used 68271822AI module; per FM45's writeup (didn't realize until now it is specific to 2019). I have completed installation of only the rear so far. I chose Rear for VehConfig1-PTS Config: I now get the icon in my cluster but it says SERVICE under the icon. Wondering if it's the wrong module, or a bad sensor. I bought the cheap Amazon sensors. No error messages when I scan. How do you check the sensors--just trial and error? I'd like to verify the sensors before I buy another module. I see 68464879AG is the correct module; but per the catalog 80 also fits MY22. Do you know the difference? Which one did you use?
I plan to order the 879 you listed. But still somewhat unclear. Catalog lists 879 as
  • W/Auto Park
  • 1500; Park Assist Module; Park Assist W/Stop Only
and 880 as
  • Park Sensor, W/O Auto Park
  • 1500; Park Assist Module; Parallel/Perpendicular
Ithink Auto Park means the truck shifting into Park when door is opened, etc. ; since 880 says both W/O Auto Park and with Parallel/Perpendicular (Active Park Sense?).
Both 879 and 880 show they fit my truck.
  • W/Auto Park
and 880 as
this is just a guess so don't hold me to it 😂 I'm thinking the 880 is for the higher trim models that have the extra sensors for the parallel parking. My truck does not have that.
With help from this thread, I got the front sensor bezels ordered and installed. Now, a new issue that I don't see any posts about. On the inner sensor in the fog light bezel, the sensor area is covered with part of the bumper structure. Looks like it may be possible to plug the harness connector to the sensor before installing the fog light bezel; but no way it could be accessed for service. Has anyone run into this problem on a BH (w/ chrome bumper)? The first picture shows the interference. The second picture is a mock up, with the fog light bezel sitting inside the bumper. Seems like this interference shouldn't exist. Guess I can drill/cut an access hole; but wondering if I'm doing something wrong.
After recently doing this mod, I have enough supplies to make 3 or 4 more sets of harnesses WITH C1, C2, C3 connectors (you do not have to source them from Ebay), that are needed coming from the parking module. I will make them and put them for sale if anyone is interested and needs to add sensors to their truck.
Endedvup cutting out this area. Doesn't seem right
I finally got it working. Thanks to all the help I received on here.
Some of these things have been covered; but just a summary of my experience. My truck required the same PN for all 10 sensors. The two with a different PN, 5YV69TZZAA, called out Sensors 1 and 6, would not work on my truck, The keying of the sensor bezels and the connectors is different.
I ordered the cheap sensors; packs of 4. Of the 12 I received; 7 were defective! Found out by scanning for errors on the Parking Module. The supplier did give me credit for 8 sensors (2 packs). [Supplier didn't seem surprised--but how do they stay in business with this failure rate]. But I would have been better off to pay the price of the OEM sensors compared to all the time I lost.
As I posted, I had to cut away metal to make clearance for 2 of the sensors. This still doesn't seem right to me.
@Y--- co se týče kabeláže pro přední část, koupil jsem si originální kabeláž, která vede z tovární zástrčky do mlhových světel / předních senzorů... Myslím, že všechna vozidla Level jsou předem zapojena do určitého bodu... například přední část je zapojena ze zástrčky v interiéru a poté do zástrčky za podběhem předního kola řidiče a zadní část je zapojena ze zástrčky pod sedadlem řidiče do zadní kabeláže...
Pokud by se někdo chtěl s touto úpravou pustit, rád poskytnu čísla dílů, schémata atd...
-=FM45=-
@Y--- co se týče kabeláže pro přední část, koupil jsem si originální kabeláž, která vede z aktivních síťových kabelů do mlhových světel / předních senzorů... Myslím, že všechna vozidla Level jsou předem zapojena do určitého bodu... například přední část je zapojena ze zástrčky v interiéru a poté jsou zapojeny za podběhem předního kola řidiče a zadní část je zapojena ze zásuvky pod sedadlem řidiče do zadní kabeláže...
Pokud by se chtěl někdo s touto úpravou pustit, rád poskytnout čísla dílů, schémata atd...
-=FM45=-
Dobrý večer, vlastním RAM 1500 Tradesman a chci si namontovat přední a zadní parkovací senzory. Můžete mi prosím poslat seznam všech potřebných dílů? Děkuji.
Understanding this is a global market, and not every post from a foreign IP and/or language is necessarily spam, please post your questions in our primary membership language - English.
It also appears you are struggling with quoting other posts and also mixing your reply in those quotes. Please repost you question clearly and in English.
