G'day from Australia
Attaboy17
G'day guys, new owner of a Laramie Sport 24. Excellent Forum to be in- lots of knowledge to absorb and share.
I would like to know if anyone has a list of functionalities that has been deactivated/ not enabled/removed to make it adapt to local Oz regs.
If not- it would be good to populate the list which maybe useful for a lot of us.
1. Activating Cargo door lights-
2. Activating DRL.
3. Activating UConnect app - for some reason we do not have the app accessible in Australia.
etc.
welcome to the forum those changes can all be done with either a Tazer or a bypass and obd port on jscan or alpha ob
Thanks. Apparently the Cargo Light has been deactivated physically by removing wires (&capped off) from connectors during the conversion process in Melbourne Australia.
So- it would require "reconnection" to happen first. My dealer advised that some wire had been disconnected to deactivate the DRL operation. Any leads on that would be appreciated.
MAYBE THIS? ANY HELP @Jimmy07
Thanks for quick responses.
Has anyone got a HDMI AI box working in the RAM1500? Something like Carlinkit hdmi adapter? I just purchased it- and it does NOT work. Not even get recognised as a carplay device.
I’ve got a carlinkit in my truck I think it’s the 2.0 or 3.0 it’s pretty old the newer one I heard is good and works with both CarPlay and android auto
Which model do you use? The hdmi adapter was a flop for me.
I got the rear cargo light on the back of the cab working again (BCM under the passenger side dash, easy enough)
