DPF Issue and questions
dougf
Pocatello Idaho
I have a question on my 2020 1500 Laramie 3.0L ecodiesel. Bought it new in July 2020 and have not had one issue until a month ago when the DPF clogged and put me into limp mode. (I use Hotshot EDT on every fill-up and have since day one.) This happened at the worst possible time, fully loaded bed and towing a 24ft trailer. However, the dash board errors were "Service Electronic Stability Control" and Service Electronic Throttle control" - nothing to do with DPF. Anyway, the dealership performed a service regeneration and I was able to get home. Since then, I have installed an Edge CTS3 and have been monitoring the soot level. It has two Regen codes that I have also been watching. One, PF_REGEN STAT - SAE, shows ON - frequently around town at city speeds, however, at city speeds the soot level continue to climb (even with this code ON.) At highway speed soot levels slowly drop - maybe 1% every 4 or 5 miles. I assume this is the passive regen mode. When the soot level climbs to around 80% - the other Regen code (DPF STAT) shows 'ON' and the In and out exhaust gas temps (DPF1_INT - SAE and DPF1_OUTT - SAE) climb and hover around 1200deg. (I'm assuming this is active regen mode) The soot level drops quickly and both times it has happened since installing the Edge CTS3, soot level has dropped all the way to 9% within 15 minutes. Both times, about half of the burnout happened before I could get on the highway to run at highway speed. AND both times when obviously in active regen mode - I did not get the message on the dash to run at highway speed until finished.
This is what has me confused. Before the DPF clog, I had only had that message appear 3 or 4 times in 5 years. Probably 60% of the miles (now at 45000), is around city stop and go. Based on what I'm seeing, it looks like active regen must have been occurring probably every 300-600 miles - most of the time without me knowing - with me possibly stopping and shutting off the engine during an active regen. This may have been what finally clogged the DPF. My main question is why I am not seeing the message that active regen is in progress? Also, if everything is normal - what other scenarios might cause the DPF to clog? Since the incident, I have performed both a Risilone Diesel Extreme treatment as well as their Diesel DPF System Cleaner. Any thoughts or inputs on this from an expert would be appreciated.
  • Like
Reactions: c3k
UPDATE: I went on the 3rd Gen Eco Diesel group on Facebook and asked the same questions. Good feedback.
1) Driving habits are probably the main contributor. Higher percentage of city driving leads to faster soot buildup.
2) Without a monitor - likely that I was stopping and turning off during active regen - BAD
3) Active regen is only reported on the dash telling you to Drive at Highway speed until the message goes away will only display after several failed active regens.
My conclusion is that to prevent DPS issues you should probably install a monitor to follow soot level and be aware when active regens are in progress to make sure you don't shutdown. A monitor provides additional benefits as well - but for an Ecodiesel, I find these to be the primary benefits
I may not be of help but, I have seen where the newer diesels should not sit and idle because of this. Also, they should run at higher RPM before shutting done.
I took my 2020 3.0 to dealer with 40k on it, after a temporary P02E8 code, code went away on my way to dealer, dealer told me soot is 78% and it failed a throttle body blade test? They wanted $2071 to replace throttle body and perform regen. I have only seen regen on speedometer 1 time, is there another way to force it to regen? AlphaOBD would be a lot cheaper than the dealer. besides the app does anyone know what cord I would need?
2020 limited 3.0
2020 limited 3.0
You're regen'ing every 400-800 miles (depending on your driving). It's happening behind the scenes and if you interrupt the process enough times, you get the message telling you to drive at highway speeds cuz you're in regen. You can initiate a regen through AlphaOBD, but it'll be just as easy to get on the interstate and just go for a drive. Having a monitor to tell you your soot load % is really helpful to manage your driving when the regen happens (at 80% soot load, typically). You can use the Banks iDash, AlphaOBD, or other apps on your phone with a bluetooth xmitter like OBDLink (OBDLink® - Home).
I ordered a KAOdTECH security bypass & OBDlink MX+, can I do a manual regen with the MX+ or do I need to get a program also like alphaobd?
In addition to a bypass and OBD reader, you need JScan (either Apple or Android) or AlfaOBD (Android only). You could have saved a few bucks (approx price of either of those apps) by getting a vGate vLinker MC+ instead of the MX+. JScan can also program key FOBs so probably best option.
Thank you, I have not looked at JScan I will have to check that out!!
I’m going to pull EGR valve a clean tomorrow, when the security bypass cable arrives I will do a regens. Light never went off and there is soot all over the intake so I figured I might as well pull it all off a clean it can’t get any worse lol.
Well no luck, JScan is pretty cool worked first try to recalibrate my speedometer for 37” tires. Pulled everything on EGR and it had a small amount of liquid residue but other than that it was spotless. Manual regen with JScan was very simple also. I guess I will just pull throttle valve and blow out connections…. and hopefully it will figure itself out, If not next step will be to replace it.
