2019 Limited will only show three tire pressures at a time, randomly drops a tire.
Noclownn
I have a 2019 ram Limited, tire pressure will only show three tires at a time. And it moves around. Bean it’ll show two fronts and one rear, then will show two rears and one front, then it’ll show both driver side and one on the passenger side, then it will do the opposite on the passenger side. So obviously all the modules are working properly. They all just won’t come up at once. Can anybody please help me with why this is happening on how to fix it.
Likely the batteries in the sensors, with a 2019 that seems reasonable.
Contact Discount Tire / American Tire, they can diagnose for free and get you a new set usually substantially cheaper than what the dealer will charge you, including installation.
All sensors are brand new and we’re just installed along with four new tires a month ago.
Gotcha, these are OEM sensors?
Either case, I would contact the shop that installed and supplied the sensors.
Oh boy, could be a problem with the RF hub. OEM should have linked in the first 20 miles or so. My two after market one`s took two days of short trips before they got recognized.
That’s my issue, because all four link just not at the same time there’s never Four at the same time. It bounces around dropping a tire. Only three work at a time never all four at once, but it moves around.
I did see that with my chinese amazon sensors, they did take their sweet time to finally link up. Reported wrong pressures for random corners, one missing randomly.
Not sure why? Maybe sending data back to their motherland...
