My ‘19 Limited has had the leather on the dash, drivers side only, bubble over time and it is dramatic now. My MVP warranty obviously doesn’t cover trim.
Who else has had this happen, after factory warranty expired, and what did you do to remedy? It was gradual and has now pulled away from the fastening on the front and edge of center speaker.
Since it has come lose to the point of an open edge, I am considering attaching a tube to a large syringe, pushing the tube all the way to the end of the pocket. I would use rubber cement or an adhesive which would bond within minutes as I work the tube back out while injected adhesive. I would have to smooth it out once the tube was removed. Seems logical without placing a sandbag on it to weight it down.
Any and all suggestions are appreciated.
