Nightshade Obsidian
Since LASFIT doesn’t sell LED bulbs up in Canada for some reason and I got zero patience lol—so finally got around to ordering and adding back the redesigned RAM OEM LED tail lights for 2025+! Huge thanks to Jeremy (if you're in here) at RetroShop for the harness (all plug and play), harness shipped and came within 2 days to me up in Canada!
Mopar OEM LED tail lights: You’ll need a set—you can buy them used on eBay or from Jeremy together with your harness as he sells them too, he can also custom paint/tint them if you’d like! However, I bought my set brand new from my local RAM dealership for a discount, they had a set available and well with tariffs and all, it was cheaper this way.
**Those in Canada only, a big heads up—you will 100% pay for tariffs/border fees when you order from RetroShop. Was less than $30 for me for just the harness, which isn’t too bad. This is not Jeremy/RetroShop’s fault at all, it’s beyond their control.
Install only took me about 30 mins to get done, harness will use the big trailer plug in the bottom/rear bumper then zip tie everything up. Installed on my 2025 Ram 1500 Sport Night Edition (Canada trim only).
For those wanting to order the OEM LED tails from RAM, below is the part numbers:
•Left: 68531051AB
•Right: 68531050AB
•Harness: 25 Ram DT (1500) to '25 LED Tail Light Harness (SET)
If you have any questions, comment or reach out! These are definitely worth it!
•Left: 68531051AB
•Right: 68531050AB
