Door Ambient Lighting
brental1
Hoover, AL
I've received all 3 PNs to install ambient lighting in my front doors. I could not find a PN for the Fibre Optic "filament" (I guess it's called". The receiver in the light measures .0222". Between 5 and 6MM. Maybe 6MM will fit when the tabs on the receiver are opened a little. Think I will order this (attached). Anyone know, or have other ideas?
I ordered and received the 6MM. It seems to be correct.
Since the middle map pocket light was eliminated at some point; I modified my 22 BH door panel. Drilled a 1/4" hole for the light to shine through; cut a slot for the "ear" on the light; built a rough post for the screw. I used Fiberflex rod. Seems it stuck well to the door panel gray material.
My only snag is the ambient connector is wrong on the new driver's door harness I bought. I need a 3 pin connector. Anyone have one?
Thanks, Brent
I lucked out on the positioning of the middle LED on the Driver's side. Seems it lights the area perfectly. The Passenger side not so good. It shines inboard too much. I need to remove the Passenger door panel and adjust the angle of the light.
