Hello all -
Yesterday I washed my 2019 Ram 1500 Laramie after it inadvertently got covered in sawdust. I drove the truck before cleaning it and it was completely fine. I used a lot of water to remove the sawdust, but nothing extreme and not directly to the engine bay (hood was closed).
I went to start it up to go somewhere and it was rough idling and I could feel a serious vibration just sitting in my driveway. It felt like an engine mount just magically disappeared and the engine was unsecured. I drove it down the road and the check light would flash and go out. I also noticed it would Rev higher (I assume to try and get to speed with a misfiring cylinder). I took it home and sat it for the night.
Today the check engine light persisted instead of flashing. I bought a code reader and it read "cyl 3 misfire (P0303)". I tried to reseat the connector for that cylinder as best I could, but it's stuck under the wiring harness. Now, if I am correct and cylinder 3 is second on the right when looking at the engine, that connector is right under the windshield where water certainly could have run down onto it. I don't want to break the connector or wires going into it, so I stopped messing with it.
I cleared the codes, and now the check engine light is gone, but the rough idling persists. I noticed when I Rev the engine to around 1100 RPM, the idling is smooth, but as soon as I let my foot off of the gas it comes back again. I drove it 50ft and the check again light is back on.
Any ideas what could be going on here? I literally just paid this off and am now dealing with this issue. My truck barely had 30K miles on it.
