2019 1500 Bighorn added UC5 -Offroad Pages
msnyder1112
Massillon, Ohio
I added the 12in UC5 to my 2019 1500 Bighorn. Enabled offroad pages and some of the gauges are wrong.
My evic is the 7 inch one, but from a 2020 so doubful I can see the pages there… however the evic does have gauges that show correct stats vs the offroad pages on the uc.
I get pitch/roll wont work since I dont have sensors or whatever, but Incould expect the gauges to carry over accurate info.
Steering angle seems to be accurate.
Any ideas? Did i miss something with alfa? Everything I read only has one setting to enable.
Connected my mx+ with jscan to see if Offroad Capable and Offroad Pages were set to “set” and they were, so made no changes. All of a sudden, the gauges all synced correctly. Unplugged it and tried to start, didn’t start. Jumped it and it started and had Service Electronic Stability Control and Service Trailer Brake alerts. Tested the battery and it seemed to have juice, but considering it’s oem battery, figured I’d replace it.
Put in a new battery and now the Offroad pages are back to weird values.
Don't sweat it. All kind of weird bullsh.... happens when you replace the battery on those trucks. Sometimes it takes a view hours to overnight for everything to work again. Just let it sit and wait.
Well, it wasn’t working originally for months, all the values were weird.
I upgraded Tuesday and the Offroad and performance pages were there and working fine (I had unlocked them a while back and was used to seeing them in the EVIC). On the way to work this morning m, they were there and then when I got to work both the Offroad and performance pages were gone from the 12.1 screen but were still present on the EVIC.
What the crap?
I use the one Infotainment send me with the programmer for the digital cluster. I bought the upgrade kit from them.
Not to hijack the thread, but are you happy with the digital cluster? I’m trying to decide if it’s worth it.
I understand it only displays factory nav. Since I upgraded my screen to 12.1 which gave me factory nav it doesn’t seem to have traffic conditions, which is making me want to use CarPlay for nav, which would take one of the cool things about the digital cluster away.
Ya, that is the downfall of the cluster. It can only display the OEM navigation map. They don't show traffic at all.
Limitation bt TOM-TOM.
Not related to the off-road pages issue, but I wanted to confirm that you were able to get the maps to display in your digital cluster/UC5 upgrade with the infotainment kit and you didn’t have to upgrade to a MY23 BCM?
