HEADLIGHT UPGRADE
Jmacnorth
Have a 2019 north bighorn and looking to upgrade to the led headlights but the oem are very expensive any recommendations? Thanks in advance
Upgrade the halogen bulbs to Lasfit LED’s. They are a huge upgrade over the stockers and don’t throw any codes. They are plug and play. IMG_0078.pngIMG_7527.jpeg
Understandable. Shifts and Grins are a good option. View attachment 176022
I like the morimotos:
I think this are just the alpharex headlights he sells from his page
here to see what OP did..
@CHeYeNNe71 i have the factory halogen- i haven't watched fuk video yet, but is what u have a direct plug and play?
I had the Morimotos in my 19 Big Horn. They are much better than stock, but the cutoff is super sharp for projectors. Mine took some finesse with a side of profanity to get them aimed properly. Held up for the 2 yrs I had them with zero issues.
The ONLY issue I had was my fault due to installing them after working 4 12 hr shifts and it was dark. The weatherpak seal fell out of the main harness connector during install which unfortunately got wet and corroded afew pins about 3 months later. Caused a short to ground on the low beam that caused some intermittent flickering. That one was on me. Easy fix. That connector is now all nice and water tight.
I had OEM LED, but they come with harness for OEM Halogen. This is before I installed the tinted PPF. There are other videos showing installed with OEM Halogen.
Ignore the higher right, parking lot is sloped, so looks more drastic then it actually is.
