Adding aftermarket amp to non amplified ram 1500
no i would get 4 ohm it's a long explanation but i will try. as long as they are crossed over 4 ohm the amp will fine. plus any amp can do 2 ohm stereo.
say you have a 3way passive crossover doing a 6.5, 3.5, and a tweeter the freq's are split say 850htz then 850 to 5k then 5k -20k, so with those 3 4ohm speakers the amp will only see 4 ohm's in a given freq range that is how passive crossovers work on components 2way or 3way. a 2 way set that's 110-5k on the mid and 5k-20k on the tweet the freq's are separated so it's two 4 ohm speakers but the amp see's it as one 4 ohm.
really it's best for 99.9% of people to just get a matched set of component's rather than trying to build a set because all the guess work has been taken out.
if you are going to get a 4 channel you should probably put all the door's on 2 channels running 2 ohm with the blockers and set the lowpass on the amp at around 5k for those then use the other 2 channels for the tweets with the highpass set at 5k that way you can set the gains so the mids and the tweeters blend and one don't over power the other. that's what i would do with the equipment you are going to be using.
i'm surprised toejam has not chimed in LOl
Also what does LOI mean lol
okay very lost now haha my mind does not comprehend this much. Well I have those ap m61se all 4 ohm 6.5s. Current speakers on all 4 doors with 0-150hz bass blockers. I believe my current door speakers go up to 15k hz. I will probably get those tweeters you mentioned earlier. So I was thinking my door speakers should be set at around 5-7k lpf and then the rest my tweeters handle… also not sure how much stock electrical can take… my subs do around 900w rms and the amp I was thinking on getting was a taramps 1200x4
Amp I’m thinking of getting
the crossovers are not adjustable on that. you would have to get a crossover or just buy a amp that has adjustable points
this one has high level inputs so ya don't even need the loc
Yeah I kinda realized that after sending the message lol
I also sent you a dm btw
