2019 Ram Sport
JulianD
Ok so I own A
2019 Ram Sport
Running 285/60/20 33.5"not sure if they are stock as I purchased the truck last November 2024.
Looks like +20 offset on stock rims
Now the 2019 Rebel sits 1" higher with a factory 1"lift.
I like the Rebel ride hight. I don't want to go over 2.5" this is our main travel truck.
The 33.5" tires on it now are **** and all AT not aggressive rubber.
I will be going to a Toyota Open Country AT more aggressive so they may rub.
To get the clearance if I need it sould I install an aftermarket kit that comes with A-arms and shocks....
Or
Try to get the factory Rebel 1" lift?
I am not a fan of leveling block style kits as they are hard on A-arms. (Had that on
my 2005 F150)
Always grab leveling struts and I also recommend doing all 4 corners for the same valving, plus being 6 years old, might as well. I'd swap control arms also, again since 6 years old.
Typical Bilstein, Eibach, FOX or Rough Country M1
^^^This.
