Anyone running 33x12.50R22 on 22"x10" with stock suspension?
AndrewGS
Houston
I found this 4th Gen online wearing 33x12.50R22 on 22"x10" -18 and it looks like a 2WD. I'm sure the same setup would work without any issues on a stock 5th Gen 4x4 with the Off-Road package.
Anyone running similar specs?
I just had a set of 22x10 - 18 offset fuel triton's delivered last week. I'm on factory air ride. Wrapping them in 305 45r22 nitto 420's. I'll let you know if there is any rubbing on stock suspension. I'm guessing I'll need some leveling links
When are you getting them put on? I’m considering that same tire and rim width/offset to run in the summer
Those are going to look sweet. Could you snap a pic of how far they stick out past the fender when you do the test fit?
I will get a couple pics. Like i said hopefully Thursday night I'll beable to test fit. I'm hoping they don't stick out very far and beat the side of my truck up
After having a few lifted diesels I’m happy not hearing the sound of rocks pinging my rockers and doors. I’m hoping for about an inch or so past the factory flares at the most
Here's a couple of quick crappy pics. The weather here has been nasty so my truck is filthy but it gives you an idea
Did you have to go with leveling links? Do they rub in aero mode.
I test fitted without the links and surprisingly no rub but very close. I raised the front about an inch and looks to have a fair bit of clearance. I don't think there will be an issue in Aero mode because generally you are only on the highway and not turning sharp.
