2025 RAM 1500 BIGHORN 3.0 I HURRICANE twin-turbo, SO, 420HP - check engine light
The procedure to check the oil in my dipstickless Mercedes states to warm the engine up and check the oil after a few minutes... yikes
It could be worse. The process for adjusting transmission fluid on my Jeep (no dipstick) requires running the vehicle then looking up the correct fill mark in a table based upon the temperature of the fluid then finally adding to that mark using a specially calibrated dipstick sold as a tool.
Have them check the thermostat as well.
RAM is using a plastic thermostat in the Hurricane which warps and can cause overheating and failure.
I believe our 2025 trucks have the 3rd iteration of the thermostat which has been fixed. That's the rumor anyway.
It was definitely the water pump (not the thermostat) on mine -- the dealer was able to see it with a borescope. While the pumps are on national backorder for 45+ days, we were able to find one of the few left in the country at a dealer in Texas. They are shipping it to us. God willing, total time down at the dealership will be less than 10 days.
I'm actually not salty about the bad water pump; stuff like that happens. But, Stellantis pushing out these trucks without parts to fix them is completely JV. The few pumps left in stock were in the system as unavailable for transfer to another dealer . . . I had to cold call the dealer in Texas myself and make a personal plea to get it. Luckily, the parts manager there was FANTASTIC. If any of you guys are from the Houston area, consider this a personal plug for Autonation in Spring, TX. They really did treat me well when they didn't have to.
it always this way on new modes i have owned many new models got in accident and truck was at body shop for 6 months waiting on parts. My grill has a huge crack on my rebel and even they are on back order. Price we pay to have newest toys lol. I don't see many of our trucks on road yet i have seen 2 other rebels and 3 bighorn and 1 rho so far.
It's the 5th version of the thermostat on the 2025 RAM.
  • Part #: 68361650AH
  • Engines: 3.0l i6 hurricane ho twin turbo ess. 3.0l i6 hurricane so twin turbo ess.
  • Replaces: 68361650AD, 68361650AE, 68361650AF, 68361650AG
I have been noticing an exhaust smell inside the truck and was still getting surging at low rpm when cruising and noticed today the clamps on both turbos that connect the cats were totally loose. Maybe hand tight… probably been like that the whole time! I tightened them up and it seems good now.
Not a check engine light but my SOS light is lite red. I can't turn it off and I haven't initiated any SOS calls. How do I turn this off?
Interesting happenings tonight....both keyfobs not recognized by the truck...only way in was the app, but not start capable...towed to a dealer tomorrow...this f*cking truck....
Well, I might have made a mistake . . . found a small coolant puddle underneath the new truck yesterday. Haven't even made it through one tank of gas yet.
Got it on the lift, and it looks like it is coming from the water pump . . . official diagnosis still to come, but my dealer tells me the water pumps are on back order, of course. Maybe I'll get lucky and its just a hose connection at the pump (unlikely).
I have a 2025 Bighorn. I had the same small puddle on the left front of the truck. It took 5 days to get the hose, over the weekend, but once it arrived it was a quick fix.
More than likely related to the telematics box.
since the first week of ownership, I had the UConnect error pop-up on the screen, and it deactivated the SOS button (red light). Finally after 6 visits they changed the telematic box and so far all is good. THey aslo changed all of the antenas and other crap that is part of the system
Mine was the water pump. There was drama around getting the part, but it's fixed now.
(2025 3.0 twin-turbo standard output), dealing with surging and erratic shifting? Tried this throttle actuator reset from a YouTube vid: Key to RUN (engine off), fully depress accelerator pedal, hold 4 secs, slowly release. Repeat 3x. Wait 10 secs before starting. Fixed my surging for 40+ miles—no codes thrown. I believe this is also causing my erratic transmission shifting. I have zero mechanical knowledge but this made me happy. IMG_0756.png
(2025 3.0 twin-turbo standard output), dealing with surging and erratic shifting? Tried this throttle actuator reset from a YouTube vid: Key to RUN (engine off), fully depress accelerator pedal, hold 4 secs, slowly release. Repeat 3x. Wait 10 secs before starting. Fixed my surging for 40+ miles—no codes thrown. I believe this is also causing my erratic transmission shifting. I have zero mechanical knowledge but this made me happy. View attachment 203259
Thank you for posting this. Are you able to post the link to the YouTube Video? Also, do I need to have a scan tool (I have a basic one)?
Helpful oil change information. I have a 2025 Ram 1500 Laramie but I'm sure this goes for all 2025s with the digital oil indicator...If you get an oil change the dealer has to reset your oil level by running the vehicle to 180 degree F, park on level ground, and then shutting off the vehicle and then press start button without the brake pedal pushed (axillary mode) for 5 minutes. The reason why I'm posting is because I recently had an oil change done and the next day my indicator showed one "pie shape" on the indicator or not at the max level, to me that meant the dealer didn't fill all 7.5 quarts so I added a quart. No change on the readout so I was going to run it and recheck and I was meeting a friend for lunch so I had time. I stopped, on level ground (I didn't know about the reset capability at this time) and was in axillary mode just listening to the radio and I get an "Exceeded Maximum Oil Level" warning...WTF!!! I have a different dealer by me and they were able to change my oil AGAIN and now the level checks okay. I hope this detours anyone from making a catastrophic mistake after an oil change.
I just did an initial oil change last Friday at 900 miles on my 2025 1500 3.0l HO. I checked oil life and level yesterday to see if the shop reset that.
Everything fine, 100% life, level right at max.
Today, out of nowhere I get Low Oil Level Add 2 Quarts warning.
I pull over into a gas station, look under the truck, no leaks. The oil level gauge showed ZERO oil in the truck. There was no puddle in my driveway when I left.
I added 2 quarts, it showed no improvement on the gage.
My dad was in the truck with me on the way to a vet appointment.
I drove slowly about 30 miles monitoring all temps and oil pressure - right where they should be.
So now I think I got a faulty warning light and 2 too many quarts of oil in the engine.
GIVE US A DIPSTICK.
GIVE US A DIPSTICK.
Get those 2 extra quarts out of there or you will be asking for trouble.
  • Back
