Was the wrong coolant added?
Apny2nv
I recently had a local shop replace my radiator due to a pinhole leak in it, could have done it myself, but had a busy week and no time. It's a 21 1500 with the 3.6. It had the original coolant in it (purple), but when I got it back, the reservoir shows a fluid that is not purple, but an off purple. I asked the shop what coolant they added and they said they added Oreilly's coolant. They showed me the container and it does not say it's for Mopar. A search on the Oreilly's website by year make and model says the coolant "fits" my vehicle. Are they correct, or should the shop replace with the proper coolant? I added a snip of what the website says is correct.
Definitely don't need dex-cool. It's an OAT, your RAM should have a HOAT coolant
I've searched the forum and some say OAT is required... First time I'm hearing of HOAT...
Prior to replacing the radiator, I was adding coolant and this what I was adding... Is this OAT or HOAT?
You have that backwards. Our Ram trucks (2013 and up) use OAT, which is dex-cool compatible. OP will be fine using that.
Some more info. FYI
Just piggybacking on this thread, but how do you check the coolant level? Can’t see thru the black rad shroud?
Take the cap off and there is a plastic dipstick in reservoir
