Cargo utility system installation
Trbsince87
Has anyone attempted to use “through bolts” and nuts to install the cargo bed rails instead of nutserts? Can you reach the back side of the pre-drilled mounting holes on the inner bed wall by reaching up from below if you remove the plastic wheel well liners?
If I remember correctly, you cannot.
Yes. Kind of.
What I ended up doing was making my own backing brackets. I cut some steel flat bar to length and drilled/tapped 2x 1/4-20 holes in each one. I then fished some string through the top pre-drilled hole in the bed, let it drop out between the interior bed wall and the outer sheet metal, and tied it to one of the holes in my bracket. I could then pull the bracket up into position, use a small pick to align the bottom holes, and then secure it in place with a bolt. I could then remove the string from the top hole without the bracket moving or falling.
I used this method to mount a couple strips of L-track in the bed without using nutserts. It took a few hours, can be done with nothing more than a drill, hacksaw, and like $20 worth of hardware from Lowe's or Home Depot.
I don't have wheel well liners in the rear (yet), but I think you can probably do it with a little patience and a long hook to grab the string.
Yes. Kind of.
Great idea. I will certainly give that a look. Thanks for the reply and suggestions.
