Need some clarification on 4WD Auto Mode
mbarber84
How does Ram achieve this setting? Are they using a front axle disconnect like the HD’s or do they have some sort of partial engagement of the transfer case? I would assume they have the driveline prepared to transfer power when the transfer case clutches engage once wheel slip is detected? Anyone happen to have the technical manual and can post a picture of the theory of operation for this system?
Front diff locked in. Clutches in transfer case that will transfer power to front axle when rear wheel spin is detected.
So there is indeed a disconnect in the front axle that engages when in 4WD auto and disengages in 2WD mode?
Yes, and it's a somewhat common failure item if you are getting service 4wd lights and it won't shift into 4wd. I replaced axle lock actuator earlier this year.
Thanks that made sense in my head, but I had a bunch of idiots trying to convince me that running it in 4WD auto was “the same as 2WD unless it detects wheel slip” and I knew that couldn’t be right. Has to have an axle disconnect or something. I appreciate the confirmation. That connection being engaged would probably be sufficient enough drag to slightly decrease fuel mileage.
Yes, on my truck it's about a 1.5mpg hit.
Just to chime in... new owner here... 1500 Lonestar (bighorn) with the Sport appearance, and big horn level 2 package. also the 3.0 Hurricane S/O. I am loving the truck, and fully expect to dread the MPG. But it's a good drive. I did notice power delivery takes a pretty big hit when dropping the pedal to the floor between 2wd feel and 4wA. I presume that's to be expected as power is split between all available wheels of course.
That, and 4-auto works by use of a clutch pack in the transfer case. So you lose power through the slipping clutches . Put it in 4-high and see how it feels compared to 4-auto. When I'm racing my 2020 Hemi at the drag strip, I launch in 4-high. There is over a tenth of a second difference between 4-high and 4-auto.
Not to be out of line or being a SA but of all the Ram 4wd I have had, why would you want 4wd auto? Just put it in 4wd high and be done with it, no slips on the clutches at all.
Because on the new rams 2025 and above 4w high keeps all power in lock steps to all wheels even when turning which can cause wheel hop and other issues with wear at speed.
Because 4-high locks the clutches so you risk damaging your transfer case trying to make turns on pavement. 4-high and 5-low are meant for use off road where the tires can slip on dirt/gravel/mud.
Part of the issue is in previous versions of ram trucks 4wh was how 4wa works. 4wa with set drive modes will direct power to all 4 wheels in various amounts and auto shift as slip is detected.
