He's using SD cards in a USB adapter. It's probably just a compatibly issue with formatting of the SD cards or file format of music filesGo to the DEALER where they can TROUBLESHOOT your ISSUE.
Yes, the same eproms as memory cards. Still doesn't change what I wrote.Do you know what's inside many USB thumb drives?
eproms
A flash drive is usually the better choice for streaming music because it’s faster, more reliable, and works with way more devices. Most cars, speakers, and computers have USB ports, so you can just plug it in and go.
SD cards, on the other hand, can be hit or miss. Some devices don’t even support them, and even when they do, the card might not be fast enough to keep up—especially cheaper ones. That can lead to laggy or glitchy playback.
So sure, the internal composition may look similiar, but there are way more differences than you think.
The Lord works in mysterious waysGentlemen,
THANKS for your assistance, POSITIVE and NEGATIVE feedback. I'd like to say that the Problem
fixed itself, but SOMEONE heard about my problem, and my 2025 DODGE RAM Bighorn was FIXED
last Thursday on the drive home from Memphis. It now works 100% correctly. Who fixed and when
I have no CLUE.
Larry
