Electrical?
Mcnasty
2020 Ram 2500 6.4L. Issue started last night. when starting it was hesitant low voltage sound it did start no messages or lights. This morning Battery was almost dead, message on dash said service shifter. No lights than that. I charged it and started up message disappeared. Check engine light came on. Took it to Autozone for codes. They were U1267, U1267-00 esm, and C2100-16 abs ground. Got home battery died again & shifter on Fritz. Help!
Sounds like you may need a new battery. Did you have AutoZone test the battery while you were there?
Negative. I replaced the battery it was 5 years old anyway and they said they don’t do patristic battery testing. New battery is in, so I’ll see if it draws and dies
