Alpharex Lux Headlight Issue
2019rams
Hey guys,
I installed Alpharex Headlights on my 2019 (factory halogen) a few weeks ago and all was fine but now I am constantly getting a dash message that driver side turn signal is out and hyper flashing.
They came with resistors for each lights and those are all hooked up.
A few weeks before installing the headlights, I did put in Go Recon LED tail lights. I’m not sure if that is contributing to the issue.
Any advice?
no reason for them to work fine for a few weeks and all of sudden stop working as intended.
check your work. there's probably a loose wire or a loose resistor connection.
Thanks. That does make sense. It is weird because I’ll get the dash alert that headlight is out and it won’t work. But after turning off truck a few times it will be back to normal. But then it will end up happening again.
Makes sense that maybe that is the issue. I’ll have to try to check out the wiring without having to take the headlight out
yeah check the wiring. but then also i've heard alpharex tends to go bad on the ram DT applications more than others, especially for those people who wheel hard.
  • Back
