Android auto, try this .
RHO
So I have been messing with my Android auto and Samsung phone since I bought the truck 1 year ago ,All the issue's we read about so I Noticed the it is very sensitive to the usb cord into the phone So instead of clipping it on where ram has those spots for it the counsel try laying the phone flat , I just drove 300 miles and never once did it cut out ,go off line nothing rock solid, Try that maybe it will help.
SO I just drove 525 miles total had my Samsung S23 Plugged in laying in the bottom of the council and never had one interruption in android auto worked perfect , just FYI maybe this will help for others , I have never seen it work this good.
If your having trouble with your cable loosing connection try one of These.
  • Like
Reactions: RHO
Or go with a wireless Android Auto dongle. my phone never leaves my pocket when in the truck unless I need to charge it. Has been stable and doesn't disconnect.
Note - I attached my wireless dongle to a USB cable with an on/off switch due to the USB outlets staying powered for 1 hour after shut-down. Better than unplugging it every time. Or just leave it plugged in, they don't use that much power.
Can you share the details of the on/off switch, did you buy that on amazon or something?
Absolutely, here you go, from Amazon, they come in different lengths to suit your location preferences, fully supports data, has been great for the year plus I've been using the cable ....
excellent thanks !
I will add to your comment. I also use the wireless dongle. However the AA Wi-Fi kept taking over my house Wi-Fi while parked in the driveway. So I deconstructed two USB cables. The cable that plugs into the AA plug under the console only uses the two data cables (clipped off the power positive and negative wires), the other USB cable is plugged into the USB port in the center console for power (this is a switched outlet that turns completely off with truck), both of these are combined before the on/off switch, then my AA dongle plugs into this.
That's interesting. Not sure why you need the on/off switch anymore though if you're using the power from the console which as you say turns off with the truck?
I might steal your 2 usb cable idea. The switched power cable works but its just yet another thing that needs to be done when getting in/out. I know ... first world problems.
