2025 1500 Trailer TPMS system not working
mark92a
All,
2025 Ram 1500 Limited with Trailer Tire PMS system from the factory. I have programmed the system as per the manual/video, decreasing by 5 PSI, the turck honks, I do the other, it honks, and appears to be all set, but when towing with that trailer selected the PSI on the screen is 0. I towed 200+ miles, it had plenty of chance to "find" the sensors.
Anyone else have this problem?
Yes, I just towed for the first time after pairing them. I'm going to try and name the trailer and re-pair them. It's going to be like a week before I'm able to though.
Well, here's the report - and it's not much of a report. I deleted, renamed and re-paired the trailer TPMS. Again, all zeroes even after two hour long trips. Next step either dealer or ram cares.
yeah, same here. I'll keep sending it to the dealer just because.
Anyone have any luck with this? I've had zero time to contact Ram or the dealer.
Mine don’t work either Guys. At least on the 12 inch screen it won’t. I do get pressure readings on the instrument panel towing screen though. But it sporadic at displaying after a restart. It’s been a real pain trying to figure it outs I am leaving on a trip with the boat later this week.
I have never had the amount of software issues with any of my trucks until this one.
What instrument panel towing screen? I see truck tire PSI, but no trailer.
Mine doesn’t work on the infotainment screen but it does show the trailer tire pressures on the digital cluster.
I also noticed that trying to change the trailer type doesn’t work and will default to dump trailer. The trailer function overall is a half baked piece of junk.
can you post a pic of this? My truck has the big screen TTPMS stuff, but no cluster screen. What trim do you have ?
I’m going to be replacing the tires on my trailer and I thought about adding some pressure sensors. Which brands or part numbers are compatible with the RAM software? Thanks
Depends on what year your truck is. I found extra sets for my '25 on ebay way cheaper than the dealer
My truck is a 2025 1500 Bighorn. Did the eBay sensor work?
