Problem with Digital Rear View Mirror
trmc47
Hopefully somebody can help me with my problem with my digital rear view mirror. I have a 2025 Ram tungsten with the digital rear view mirror as standard equipment. My mirror works for about 10 minutes and then starts flashing on and off. The longer it is in the digital format the more rapidly it flashes on and off. If you turn on the headlights, it stops flashing and works for another 10 minutes and then it starts flashing on and off. If you are driving at dusk, the mirror will work normally as soon as the truck detects darkness and dims the instrument panel. It will work normally until the truck detects enough light outside to brighten the instrument panel. The truck has been back to the dealer numerous times and so far they have not been able to fix it.
i
i
Sounds like the ambient light sensor is bad. Time to head to the dealer for warranty work.
