Transfer case and differential fluid
Eaglehemi345
Is there anyone out here knows what kind of t case and diff fluid 5 gen ram uses. I have a 2020 sport.
T-Case: MOPAR BW44–44 Transfer Case Fluid
https://www.carid.com/2019-dodge-ra...nts/mopar-transfer-case-fluid-2763458843.html
Diff:
Front: MOPAR GL-5 Synthetic Axle Lubricant SAE 75W-85
Rear 3.21: Mopar Synthetic Gear Lubricant SAE 75W-90 (MS-A0160). Limited-Slip Rear Axles require the addition of 5 oz. (148 ml) Mopar Limited Slip Additive (MS-10111)
Rear 3.92: MOPAR Synthetic Gear Lubricant SAE 75W-140 (MS-8985). Limited-Slip Rear Axles require the addition of 5 oz. (148 ml) MOPAR Limited Slip Additive (MS-10111).
Owners Manual:
EDIT: I added 3.21 diff fluid.
What year is the linked manual from? In my 2020 manual the transfer case requirements are:
Also, the REAR differential fluid requirements are different depending if you have 3.21 and 3.92 gearing and/or max tow:
Seems like the Fluid I found is more for the 5th gen in general. 2020 Specify a new fluid for different types of T-cases.
The specified fluid for the 48-11 transfer case is Mopar 68049954AC, which is repackaged Mobil Fluid LT. You can't find the Mobil Fluid LT by itself outside of 5 gallon buckets, unless you get the OEM rebranded packages like the MOPAR fluid here.
RedLine recommends their MT-LV in the RAM transfer case, which is what I use with absolutely no issues:
From service info on tcase fluid
This is what my local dealer gave me. I bought it of my vin number. That's for 4wd auto transfer case.
So i have a 2019 "new style" ram 1500 big horn with the 4hi/4lo/4auto transfer case. I'm assuming i would be the 44-11 borg Warner? I'm trying to source NON dealer fluid right now. They just quoted me 97$ per quarter and I just can't in good conscience pay that.
