HELP .... Adding Blind Spot Tail lights and Mirrors........ NEED ALPHA OBD / OBD MX+ .......Directions & Blueprint Please
richbc
2021 ram 1500 laramie sport with lots of up grades
1) HELP ....Adding Blind Spot Tail lights and Mirrors........ NEED ALPHA OBD / OBD MX+ Directions.......I Need HELP Programming and adding BSM to Computer......ANY Directions & Blueprint would be appreciated.
2) Trying to do something else as well. i have not started but need some help and direction. These Mirrors are OEM BSM, Heated & 360 camera (Picture below)..... truck is 2021 ram 1500 laramie sport with lots of up grades but still has a 8.4 inch radio with uconnect 4.......i have all the fakra cables needed to run for the cameras on these mirrors but i believe i need a module in the picture attached. this could also be the wrong part needed. I have all the fakras cables to run both ways and to the uconnect module. ... i could be completely wrong ..... Goal is to get cameras working on the mirrors. Any help is appreciated and directions is greatly appreciated.
Located in Essex County, New Jersey. if anyone on here is close and is knowledgeable of all this.
There are 2 how to threads pinned in the modification section. They should help you with everything you need.
Have a 'LOOK' - lots of info...
-=FM45=-
Thank You ... but im not finding anything about the alpha obd / mx+ sequence or coding to add the Blind spot light and mirror to the computer..... any other direction would be appreciated.
I see the info on 360 camera....i believe i have the wrong part not the CVPM
Read this thread. All info in there.
Appreciate it. Thank You.
