33 gallon fuel tank
Ram 1500 has a 26 Gal tank actually and the upgrade is 33 Gal for the Ram 1500. You can get the parts from Mopar also you need to buy the evaporator canister for the 33 Gal as it is different than the 26 gal version. Dealer will not sell you the upgrade as they do not want to take responsibility for the upgrade. My dealer which is in Canada nit US did the same, however they said they will install a new 33 gal tank is i provide the parts.
some did come with the 23 tank.
Some RAM 1500 model with etorque comes with 23 gal fuel tank bit the non torque 5.7l has the 26 gal or the upgraded 33 gal. Easy to upgrade if desired make sure you get a new evap and the shields for the bigger tank,
I have a 33 gallon tank and can’t make it past 300 miles before filling up. I can only imagine what life would be like with a 23 or 26 gallon tank.
I wish they made a 50 gallon option
They do:
190 LITRE REPLACEMENT LONG RANGE FUEL TANK​
to suit DODGE RAM - 2016-PRESENT - 1500- DT MODEL- PETROL MODELS - LARAMIE & BIGHORN WITH SHORT TUB - (DOES NOT FIT TRX OR BIGHORN LONG TUB 6.4ft)​
PART NUMBER: DRAM16R3
TANK TYPE: REPLACEMENT
CAPACITY:190 LITRE
FILLER POINT:STANDARD
FUEL SUPPLY METHOD: STANDARD
TANK LOCATION: REPLACES VEHICLE STANDARD TANK
FITTING TIME: 4 hour/s
LOL....and there goes the limited weight capacity
i thought I had.
It hurts bad enough already when I fill up my 33 gallon tank with the Premium gas that my new SST HO requires...
I feel your pain. The TRX also requires premium. $100/fillup, at least once a week, it gets old.
But the first rule of sh1tty mileage club is you don't complain about the sh1tty mileage.
It’s called Smiles per Gallon😬
