Heads-Up Display
MLB12
Calgary, Alberta Canada
I've noticed that the HU display on my '25 Longhorn LTD isn't displaying level on the windshield. Has anyone else experienced this? I'm going to talk to my dealer tomorrow to see if there is an adjustment for this.
Just for the heck of it… have you tried to raise or lower the height to see if changes, and/or change the content it displays?
Not sure if they use the same unit as my 23 but I haven’t heard/seen of this issue anywhere yet.
When you say not level, are you talking like a degree or two off, or way out of whack?
I noticed this on my Limited as well when I picked it up but it was set from factory too high. I lowered it on the windshield and it's much closer to level. I thought I ws the only one, but it may also be the perspective of the sport hood?
If I could gas, it probably has something to do with the curvature of the windshield. If the heads-up display is set too high, it reflects on a part of the windshield with a different curvature then when it's perfectly adjusted to the driver
Voice to text if I could. Guess is what I meant
I have my height set pretty high for HUD, I’m 6ft tall.
I actually paid attention yesterday and for me, it looks like the right side of the HUD is a tick higher than left.
Could be the curve of the hood or windshield throwing it off… but I have to be honest, through 19K miles.. it’s never bothered me or occurred to me to even think about it until this thread. And… probably won’t think about it again :0
It's the hood most likely. Just got my truck a few hours ago and remembered this post. Definitely looks lop sided due to the hood, but definitely is level after looking at it closely. Optical illusion, for me at least.
I had the HUD on my '21 Limited. I had it turned on for a while. I tried different configs for what it displayed.
After a month or two, I turned it off and never turned it back on.
I got a new '25 last week. The HUD was on by default. I have adjusted the config and left it on for now. But, I have a feeling I'm going to be turning it off again soon and leave it that way.
If I could get it to display where it was only "on top" of the hood, I might leave it on. But, I have it set as low as it will go without starting to cut off the bottom, and it still shows on the windshield where it's mostly blocking my view of the road, not the hood.
I really just don't feel like I have any use for it.
mine is set on the top of the hood and it's set just perfect. I'm 6'1. How tall are you? I thought mine was crooked when I first got it, but after awhile I thought it could be an illusion from the hump in the sport hood. I've since lowered the HUD since I picked it up new. I've noticed that the lower it is, the more level it looks. Love mine -- would never turn it off.
I'm 6'1".
I also have the driver's seat set as low as it will go. Maybe if I raise the seat up some it would make the HUD look lower.
I will experiment with that, just to see.
I've noticed it too. My wife's Kia allows you to rotate the HUD to compensate for this. Not a fan of Ram's limited adjustments.
