I found some Method Wheels that I’d like to buy, but haven’t been able to verify fitment. From what I know, these should fit, but anyone have any more input?
I’m planning on doing a 2” level and 295/70 Toyo ATIII.
The bore size is 106.25 vs stock 77.8. So you will need hub rings. The only other caveat is not all 18" rims fit. It's all about the ID sizing as 18" rims fit close to the brake caliper assembly.
Some don't fit. Others just require specific placement of the balancing wheel weights during installation.
Thanks for the response! I am a little worried about the inside diameter. Finding the inside diameter dimension of any wheel is harder than it seems like it should be. Any advice other than pulling a tape measure with the wheels in hand?
You nailed it. The actual wheel ID typically is not shared data which makes it difficult to know.
If you do some searching. You can see what people have had luck with. It does seem like (most) Fuel and Method wheels fit. But no guarantee with that statement.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
