Map not loading in instrument panel in front of steering column
I Stand corrected. Lasted a couple of days.
I Stand corrected. Later a couple of days.
Same on my end. Worked for a few days and then continued to have problems with the map displaying in the cluster with not much consistency. I was not having this problem prior to the most recent UConnect update in my ‘24 limited. Since this update, I have also had my touchscreen go crazy a few times, not showing the bottom selection bar that allows you to navigate to comfort, nav, vehicle settings, etc and trying to resize. Quick fix for that has been to press the manual “Mode” button to control comfort settings. Glitchy and frustrating to say the least with how much these trucks cost.
Let the thread know if anyone else has ideas. I haven’t tried disconnecting negative battery terminal like someone suggested and that may be next step as resets aren’t working.
I can now confirm that a factory reset does nothing. Worked for a few days. Back to being intermittent. I’ll keep troubleshooting.
What is so great about the nav in the instrument cluster? I have it on the big screen so don't need to see it twice. It only shows the Tom Tom nav right? If so, I don't use it anyway.
Ok, Karen.. some people may actually use it so they aren't always looking to the right to see where they need to turn.
I Wish I was writing a solution to this issue. I thought I had it figured out yesterday when I thought the issue was somehow coming from my Android Auto connection. But I was wrong, again. I've messaged RAM Directly and they're troubleshooting with me.
Just got truck back from dealer. They claim there was a hidden code somewhere deep that only their laptops will pickup. This led them to a proxy calibration they believ this may have been the culprit time will tell
By any chance, has the problem been solved for you?
Same problem here. Anyone with a Fix?
Picked up a brand new 2025 ram sat. Today the map in the instrument panel in fornt of steering column just keeps saying loading maps but will not load. Navigation on the console in middle of vehicle works still. Is this an easy fix or do i need to go back to dealer?
Myn2023 ram revel does the same thing and still isnt working. ( I have figured out if you change the profile setting color ) it will work again until you turn the truck off again.. the dealer doesn't have a clue.
Same with my 23. Happened after the last update. Has anyone tried to have their dealership reflash the software?
That issue usually pops up when the system needs a quick reset. Try shutting the truck off, opening and closing the driver door, and restarting after a few minutes. If that doesn't clear it, it’s likely a glitch they'll need to update or reset at the dealer, probably a quick fix under warranty.
I just had my dealership reset the UConnect software. Will circle back and update with my results.
NOT a solution, but What I've been doing lately is only using the instrument cluster navigation when I need it. So basically i just leave my cluster on other screens 90% of the time. Then whenever I flip to the navigation, it always works. So I guess that's the software's way of telling me "It's not meant to always be on, use only when needed" lol.
Mine does not always work if I cycle to other pages on the cluster or if I have another page pulled up first on a start.
I have noticed that it always works in the morning when the vehicle sits overnight. However, I’ll drive into work with it functioning, and work 9 hours with the truck sitting in the parking garage and it will be blank when I drive home.
If I turn the truck off in the morning after starting it that 1st time, the map won’t work. Makes me think it might be a combination of the computer “sleeping” and the day/time rolling over or something.
I haven’t taken it to the dealer to see if this could be rectified there.
Just chiming in to report that my ‘26 Laramie intermittently will not load the cluster maps. Just shows “Map Display Loading”.
Just joined this forum for this very issue. I have 2024 Limited Longhorn and this happened right after the last software update. the Navigation on the instrument panel works.....sometimes. Please post if a resolution is found.
My 2023 Limited is doing the same thing. About half of the time the screen flashes once and no map. The other half of the time it flashes twice and loads the map fine. Wish these small issues would get fixed.
my 2023 Longhorn limited are having the same problem just after the latest s/w updated in spring. Every morning after a sleep over night, the map is loaded mostly OK. But after it shutdown and startup again the rest of the day, most of time it is just a blank. Not using the navigation over cluster quite often before but I want it to be resolved before my manufacturer warranty expiry.
Brought it to dealership three times already, they updated maps, refreshed the uconnect s/w, and replaced my radio even :). Nothing helps. I told them I am pretty sure it comes from the latest s/w update since it had been working fine over the last two years before the update. But I think they just can not say Yes.
My car is 35980 miles and only 20 miles to have the warranty expired. I escalated the issue to RAM, they gave me a reference number, asked me to bring it back to dealership and they will work with them to get it fixed. Scheduled the date at the end of this month, I do not know what they can do since they already replaced the radio, unless they have a fix in the coming s/w. Anyway they commit they can fix everything, maybe I am just wasting my time....
By they way, I figured out every time I just need to click "clear user data", it will reload the maps and push it to cluster panel, can work for a day or so. Then it is gone again.
It is without a doubt because of their latest update. My 24 was fine right up until that update then this issue happened. Updates are supposed to fix bugs, not create them.
2024 Ram TRX navigation not loading in the digital instrument cluster. This started about two months ago and yes you can switch between themes that will force it to appear but after the truck sits for 15 minutes it goes away. This is what my dealership has done so far. 1, replaced the digital instrument cluster with no fix. 2, replaced the uconnect 5 nav radio with no fix. They opened a STAR case with nothing and now advised they need my truck for a few days and plan on having an agent sent out to assist with the issue. Will keep everyone updated on what they fine.
