2025 trailer lights
Rebel2022
Alberta Canada
Been seeing a few issues with 2025’s not lighting trailer lights and now i’m having a few weird issues. I have 3 trailers, 20’ flat deck has all incandescent, no brakes and works fine. 14’ cargo all incandescent with trailer brakes and the driving/marker lights won’t light at all. Brakes, brake lights and signals are fine. Truck flashes warning trailer lights out. 30’ travel trailer, mostly incandescent with a couple leds. All lights work but truck flashes warning trailer lights out. Another weird thing, towing the cargo trailer the other day on a couple hundred km highway trip and noticed the battery volts dropped to 12.6-12.8 range (whole driving) never saw that happen before, always 13.8-14.2 unless start/stop. Then i get a service shifter warning and the light on the console shifter goes out. Then a 4wd system not available warning. Get home, unhook and then over the next day or so battery voltage slowly went back up to 13.8-14.2 as always.
Anyone have any thoughts?
Guess no one else having issues. Messed around today with the cargo trailer. It has all incandescent bulbs, x2 tails, x4 front amber, x7 marker x2 fender and x1 license plate. Confirmed power to marker light blade on truck with lights on. Plugged in and turned lights on and they flashed for a second and shut off. Could not get it to do this again without unplugging and cycling the ignition. So I unplugged the tails and turned the lights on and they stayed on this time. Plugged tails back in and unplugged 4 markers and tried, lights flickered and shut down. Kept unplugging more marker lights and finally they stayed on with 2 tails, one license plate light and 4 markers. So the truck obviously has some kind of built it sensor telling it too much voltage with lots of bulbs and trips some kind of circuit. It must be set to low so we’ll see what the dealer says about it.
One more thing I can’t figure out. The battery blade on the truck plug does not output 12v at anytime, key on, key off, plug on plug out nothing. Looked for a fuse related to this in the truck, could not even find a fuse relating trailer/plugs.
Does the 2025's 12v blade run through the itergrated trailer brake controller?
"The battery blade on the truck plug does not output 12v at anytime, key on, key off, plug on plug out nothing. Looked for a fuse related to this in the truck, could not even find a fuse relating trailer/plugs."
I have no idea?
You asked for thoughts, so here goes.
1) Check the connection on the backside of the 7 pin recepticle. I recall reading about problems getting it to seat properly.
2) I think the charging line fuse is F01 on the interior fuse box, according to this video. There are also two fuses in the underhood fuse box labelled ITCM. I believe that stands for integrated trailer control module
Thank you for this, I will be checking.
I also have issues with my trailer lights on my 2025 limited.
I have a 2 year old single axle PJ utility trailer with LED lights all around, 4 pin connector. Works 100% fine on my wife's Jeep.
On the RAM, if I have my headlight switch in Auto, during the day with the lights off and the trailer hooked up, it will complain to check the trailer wiring. Moving the headlight switch to either ON or OFF will clear the error most of the time. Strange thing is all the lights work fine. Hitting the hazard lights show the brake lights work and turning on the headlights will light up the markers and license plate, but the truck still complains. And i have never been able to get the trailer light test to do anything, ever. We towed the ATVs this past weekend and the error was gone all the way up and the truck complained all the way back. But, as far as i can tell the lights always work, pulled over twice to check. Annoying...
Same on my 25 limited.
been having same kind of issues with our TT. 2022 imagine. connection check and tail lamp check on screen while towing. stopped and check all lights are on and working. in research am finding finding others with issues on 2025 1500. looks like Ram lowered the capacity of the trailer plug. seems too much draw and the module errors out. going to try to change out TT lights with LED bulbs. seems to be typically engineering issue with no insight as to what they may be changing....
google. "2025 ram trailer lights optimized for led Ram 1500" some great discussions to follow on FB groups.
If you have the hurricane engine the only fix is to convert to LEDs the computer only allows up to 3.45 amps draw onrunning lights. My trailer has 16 incandescent and draws,7.7 amps. Tail lights draw around 1/2 amp so cn only run 6 , you need 4 at a minimum, 2 tail,2 license so gou are screwed. Do not let the dealer say it is your trailer. You will get several codes and dash displays but none are what is happening. They charged me $199.00 diagnostic fee. This is their justification.
Well add me to the list of trailer light problems. Left for Wisconsin yesterday in the dark. All lights worked fine on the trailer. Got to the truck stop to get ice and when I left all the running lights went out and the dash said check trailer connection. Mind you all the other lights worked just fine left, right, stop and emergency. So I stopped again and unplugged the trailer and plugged it back in. Nope , so I shut the truck off and went back and plugged them back in and then restarted the truck everything worked for a 1/2 a mile then the running lights went out again. By now I am p—ed off and wishing I never seen this truck. My trailer is 100% LED lights and works fine on any other truck. I ended up having to run in the dark with the Hazards. 2025 and something as simple as trailer lights won’t work. I don’t know what to do I haven’t seen a fix posted anywhere but lots of people with the same problems.
I’m running 100% leds on my Ranger boat trailer and I’m still haveing the issues posted here and other places on the web.
Having issues as well with my MY25 1500 limited randomly telling me to check trailer connection. Lights still work when I get the message and the error goes away on its own. I’ve never had this happen with my 22 1500 Laramie.
I left rice lake wisconsin Saturday morning lights all worked fine. I got just south of Madison on the interstate and hit a little rough bridge crossing whoopy do. instantly the check trailer connection came on Running lights went out but rear tail, stop, turn still worked. but it showed the little flashy warning sign all the way to the rest area. the only way to reset the system was to shut the truck off unplug the trailer and replug it in, start the truck and reselect the trailer. so I get about 50 miles from home from their and it does it again. it's not the trailer I know that for a fact. all grounds good and all lights good. trailer plug is a fixed recoiled chord round 7 pin plug.
i have not had the error go away on its own yet. I have to shut the truck off and redo everything for it to reset.
Hi I just picked up a 2025 2500. I went to tow for the first time yesterday and like many here my my lights flipped out as soon as I plugged in. Has anyone heard of a fix from RAM?
Might want to follow the hdrams.com site.
That said, seems to be an issue for many 2025 RAM owners, several reporting both Trailer Brake Control lever module fixed it, some still having issues.
I'd also recommend anyone that has the old style 7-pin plug change over to the new style. This particular fix has been an issue going back years.
There's also some recent activity in the TBM technical sticky related to these issues.
Update on new part number.
Had my truck in today, they replaced the 7 way plug and the tow module behind the seat. That module has been updated by Ram for the the trucks built with the integrated brake controller, trailer lights and ttpms from part number 68602159AE to new part number 68602159AF
I have not tried my trailer yet to see if it helps but it’s a developement.
The service notes say that the tech was able to make the module lose communication by simply tapping on the original one.
Hum, well I don't have the brake controller model on the dash, so I don't know about tow module behind the seat, but I have all the errors show up, loose connection, no trailer, blind spot not detecting trailer etc. Does anyone know if the module behind the seat is the same or different for the RAMs with the dash controller ?
I added a relay to my trailer and that fixed the issue. So my truck running light circuit is only seeing and powering the relay.
