Adding front and rear parking sensors?
Hey, I swapped my front bumper for a Westin Outlaw. I thought I put all the sensors back in the same orientation but I am getting continual warnings when I drive. The pass side seems ok but the front is super sensitive and randomly senses stuff that is not there and the driver side is almost constantly jumping from not sensing anything to warning red. I might have swapped the drivers side sensors (very possible actually). Would this cause the funny action? Anyone know where I can find out if I have the right sensors in the right location?
Harness part number is: 2021-2024 Ram 1500 - 68489203aa
The 2 sensors on the drivers side each have 3 wires. One of them has Gry, Y/W, Blu/W the other is Gry, Or/W, Blu/W.
Right now I have Gry, Or/W, Blu/W as forward facing/front.
I have Gry, Y/W, Blu/W closer to the tire in the far left/drvr position.
Truck is a '21 Bighorn 1500DT. Thanks for all the info so far!
on my truck(21 TRX) all the fronts sensors are the same part #. The only difference was the bezels they go into which I guess changes the direction they point slightly.
If this is the bumper you have it's very possible the sensors are just picking up the bumper itself based on them being recessed slightly and having the tubes in front of the sensors View attachment 191230
Yep. That's the one. Man, I hope its not picking up the bumper. You'd think they would have figured that out before now. It's been out for many years. I hope someone can help me out with either a schematic or pinout for the harness I listed above so I can rule out misplacement of the sensors themselves. Are the sensors sensitive to clocking as far as "is there a top and bottom"?
Any idea where I could find the schematic or pinouts for the connectors on the harness?
I thought that was the case but even in the PDF directions for adding parking sensors in this very thread they list different part numbers for clocking left or right of the connector housing.
Front Bumper
Sensors x4 5YV68TZZAA
Sensors x2 6MK25TZZAA
In case it helps anyone. Here is the parking assist schematic for 2021.
I'm not sure it matters which sensor is where, at least in my 2020, all the sensors were the same. And the plugs on the harness are pretty self explanatory on which sensor they go to based on length and location of the pigtails of course my aftermarket bumper doesn't have the two sensors on each side so close to each other.
I definitely saw a thread(maybe on the TRX Forum) that said which way they are clocked is important. I will try to find it, but I think the outer two both sides the plug was pointed toward the center of the bumper and the inner two the plug was pointed toward the edges of the bumper
found the thread and what I said above is correct. Outer two both sides the plug is pointed toward the center and the inner two are pointed toward the bumper edges.
Thanks. That's how I have it.
I ended up just taking them all out, cleaning the connectors, reinstalling them to the harness and mounting them to a stick and testing them one by one. Everything worked so I reinstalled them and assumed the problem had to be with the positioning. I just drove the truck and whichever one acted up I moved it's position until it worked. the movement was literally a degree or two and maybe a mm in one direction or another. Its hard to be precise with the way they mount. Eventually after a couple adjustments they all started working like a peach. I halfway wonder if they don't just do some sort of self calibration.
Hi All,
I am working through the process of adding park sense to my 2024 Ram 1500 Limited. I am hoping to get some help on the parts list needed for this. I found the VIN of a truck that is the same trim but has park sense, Limited with Limited level 1 package. I am finding some differences that I want to make sure are not an issue with the process described in this thread. I do want to caveat my truck does come with air suspension, someone had mentioned air suspension in reply so I want to just throw that out there.
The biggest thing I have in question is the rear park sensors. The limited with park sense has 6 sensors in the rear. All of the descriptions in this thread only have 4 which seems to be Laramie and below trim models. The limited level 1 package also comes with the Park assist package which might be the reasoning for the extra 2 sensors in the rear.
I still have questions about the harnesses and other wiring but want to start with the components first. Should I use the Laramie or below parts without park assist or should I use the limited parts which appears to be slightly different but closest to my model? Thank you for any and all help!
@Y--- as far as the wiring for the front, I bought the OEM wiring harness that goes from a factory plug out to the Fog lights / Front sensors... I believe all Level vehicles are pre-wired to a certain point.. for ex. the front is wired from a plug on interior then out to a plug behind the drivers front wheel well, and for the rear, it's wired from the plug under the drivers seat out to rear harness...
If any member wants to tackle this mod, I will be more than happy to supply part numbers, diagrams, and etc...
-=FM45=-
FM45 would you be willing to help me out.....I'll pay you for your help
I successfully completed my mod and wanted to add some information in things I learned.
I did not remove the front or rear bumper or drivers seat to complete this in my 2024 Ram 1500 Limited. I can see how this would make things easier but I don't know how much extra time it would save. Here is my extra information:
Paint the sensors as a prep step beforehand or complete the setup in an order so the paint is dry by the time you are ready for installation.
Front Setup:
Lift the front end so it is easily accessible from underneath.
Remove the Center Grille first from underneath, this will help to make the left and right fog lamp covers more accessible.
Remove the Fog Lamp, wheel well cover, at least the bottom front covers (the entire wheel well cover would make the fog lamp removal easier)
Although it is tight you should have enough rooms to replace all the parts and run the new wiring harness.
I put in the new harness as I pulled out the old to make sure all the placement was the same.
Rear Setup:
The fit is tight but with patience all bolts/nuts wiring is reachable. The tightest fit are the outermost bolts at each edge of the bumper. A small socket gets the job done 1/16 of a turn at a time.
Remove the Tailgate and any rear license plate. This will make the center most wire harness connector accessible from above.
Internal Wiring Harness:
I am sure you can build your own but the one from Jimmy was perfect, no errors, every cable was wired. Maybe you save $100 for DIY, but given the ease with and accuracy it isn't worth the savings in my opinion.
Remove Driver Kick Plate, Driver seat belt cover, Driver seat outer cover (this order as the seat belt cover, covers the seat cover)
Internal Wiring under drivers Dash:
The trickiest part is getting access to the plugs and as several mentioned they can break off the plastic mount. So here is what I found.
Unplug all 3 plugs on the plastic mount. Plug A, Plug B, and whatever the third plug is not used per the pictures in this thread (plug C).
Unbolt the plastic mount, there are 2 bolts coming from the rear wall that need to be taken off. Unhook the hood cable and allow to hang free.
Using advice from Quietpeen and his pictures on these plugs, you can orient/turn the mount enough to unlock Plug C, and detach the harness from the mount (Christmas tree plug).
Pull the hood cable through the mount. This will give you enough movement to turn the mount and access the back side of Plug A to remove it from the mount. See Quietpeen pictures to identify what you are looking for.
At this point you will have enough access to Plug A, and Plug B (still attached to mount)
I could not remove Plug B, but with everything else removed I had plenty of access.
Again see Quietpeen Pictures and descriptions as well as others details in this thread for proper wire pinout/procedure.
Internal Wiring Under Drivers Seat:
After removing the panels described above you just have to move the carpet a little to access the plug. Remove the plug snapon cover, and cut zip tie for proper finishing. Rezip tie new wires with old wires when complete.
Remove the three nuts holding the plug down.
From underneath the truck remove the three nuts holding the cover in place (directly below the aforementioned plug). Unlock plug from underneath and disconnect.
The plug should be reasonably accessible now. For each pin being added remove the blue rubber grommet in the plug before inserting the new wire/pin. I could not figure out how to use these grommets so I just sealed the pins with a little silicone.
Alfaobd programming:
I used the windows version so maybe the instructions weren't as obvious as described.
Use advanced mode to select your interface. Go back to Regular mode.
Brand > Dodge/Ram; Model > Ram 1500; Function > Body Computer; ECU > DT MY2022+ PowerNet (or the one that matches your model); Connect
After Connecting go to "Active Diagnostics"
From the Drop Down select "Car Configuration Change"
From here you should be able to find all of FM45 settings.
Hopefully this helps. Total time probably took 10 - 12 Hrs. If I had to do it again, after learning the above and learning the location of everything I think it could be done in 3-4 Hrs. But be patient and take your time is my advice.
Made the 3 required wiring harnesses today. Still have lots of parts to get ordered, but i wanted to make sure I could get the harnesses figured out and done before spending all the money.
I’m going to try to get the module and these pinned into the existing harnesses tomorrow. Will try to get pictures along the way
Did you buy and modify the harnesses (as I think FM45 did?); or did you build them from scratch. If scratch, do you have the PNs for the 3 connectors, and the pins for each? Thanks, Brent
I made it from scratch and used the write up from post 15 i believe. However for simplicity I'm pretty sure Jimmy07 makes these harnesses.
I'm looking to do this on my '24 Rebel, but when searching for the C1-C3 connectors, it looks like these connectors come with wire and connectors and each connector is between $80-$100. Example: Genuine Mopar Wiring 68080557AA for sale online | eBay. Is this right? I would think you could just buy the actual connector.
Ryan
I'm trying to build the 3 harnesses (without using the kit). Did you find PNs for just the connectors and pins?
