New wheels (0) offset question
Juli_hoop
Anyone know if a wheel with zero offset will cause any rubbing issues? It’s a stock 2019 ram rebel crew with stock tire size. Cooper discoverer at3 xlt tires if that helps. Going to an 18x9 wheel also.
You'll be roughly .75" further out, which isn't much. If you have a tape measure, go to your tire and measure that and you'll know approximately how much further out they will stick.
Need some opinions. Bronze or black wheels?
Zero offset
Consider a stock rim with a stock tire size.
Draw an imaginary line through the ball joints to the ground. This is somewhere in the contact patch of the tire on the ground.
If you make the rim wider or narrower, then the offset needs to change to keep the same relative point of contact with the ground. If you make the tire taller or shorter, then the rim offset needs to move out or in (respectively) to maintain a correct contact point in the tire contact patch. Anything else makes the handling have bump steer in one direction or the other.
Even getting all of these right, may still ave to evaluate camber, caster, and toe to get the geometry right.
Another vote for bronze. Friends don’t let friends get black wheels. Seriously, your opinion obviously trumps ours, but to me, contrast between tires and wheels is much more attractive.
Below are my platinum Fuel Blitz 18” +1 with Yokohama Geolandar X-AT LT295/70R18, on about a 2” lift. The offset plus tire width moves the outer side wall about 1.1” further than stock.
(I got these wheels when I had a silver Ram. I think bronze would look good with Delmonico Red, but I could never do that because it makes me think of FSU).
I have 0 offset 20x9 on 35’s if you have oem flares it will sit flush with them. I rubbed initially but that was caused by tire size not offset.
